Thanks for the add
Thanks for the add
  • #40459
    Adrian Harrison
      @adrianharrison27934
      Adrian Harrison
        New member from Canada BC, I bought an older lathe two months ago which is an m type Drummond..
        Really happy with what I bought and now I just need to learn how to use it 😁
        #389048
        “Bill Hancox”
          @billhancox
          Welcome. Just one piece of advice. Before you power up, thoroughly check it for freedom of movement. Do your best to find a copy of the owners manual. Buy a good training manual, if necessary one for any lathe of comparable size. The manual will provide you with generic safety and operation information. My learning curve took about 6 months. Good Luck.
          #389062
          Brian H
            @brianh50089
            Welcome Adrian. My first lathe was also an 'M' type Drummond and I had many happy hours on that making things.
            You will find information about your lathe here;
            http://www.lathes.co.uk/drummond/index.html
            #389064
            David George 1
              @davidgeorge1
              Hi Adrian I have an M type lathe like you although i have done a few mods to mine like just pluging the first jole in the bed to prevent small parts disappearing to fitting a quick changed toolpost. It's worth having a look in my photos to see results and ideas.
              David
              #389160
              Adrian Harrison
                Posted by "Bill Hancox" on 03/01/2019 05:19:02:
                Hello Bill, I diid go over the lathe with some good quality oil and checked everting was moving as it should be before i turned the motor over.. I did find the back gear would not stay engaged but thats now not a problem after some good use..
                i bought the Amateur's lathe book about 4 years ago and must of read it about 20 times over but like you say its going to take sometime to put that into practice
                #389161
                Adrian Harrison
                  Posted by David George 1 on 03/01/2019 08:20:51:
                  David
                  HI David, i really like the look of your M type so I'm sure i will be asking you some questions as i can already see a few modifications I would like to make to mine.. That plug is a really good idea and one i will do this weekend..
                  I bought a copy of Model Engineers workshop last month because it had plans to make tool holders, that could well be my first project and along with the other projects that i will need to make to make them
                  #389162
                  Adrian Harrison
                    Posted by Brian H on 03/01/2019 08:12:08:
                    Thank you for that link Brian and that traction engine you have in the picture looks amazing!
                    #389164
                      Welcome to the forum Adrian,
                      A surprising number of Drummond users around here!
                      larry phelan 1
                        @larryphelan1
                        Having read that book,it,s just a matter of putting it into practice,you can,t go too far wrong,it,s all solid advice.
                        Just be warned !! Once you start,there,s no going back,you,re HOOKED !!
                        All that aside,you have a nice little machine and I wish you many happy hours with it.
                        Have fun .
                        PS Make sure to get a big bucket for the swarf,you might be surprised how fast it mounts up !
                        #389168
                        larry phelan 1
                          @larryphelan1
                          Have fun .
                          #389175
                          David George 1
                            @davidgeorge1
                            Hi again Adrian I have sent a message. Check at top of page after loging in.
                            David
                            #389208
                            Howard Lewis
                              @howardlewis46836
                              Welcome to the swarf making addicts club! LOTS of help and advice on here, plus some banter!
                              The more that you use the machine, the more things that you will find that you can do with it, Some of which, at one time, you would never have thought possible!
