Test Thread for using Quote
  • #39022
      Try quoting an earlier thread here or linking to another
        Better give you a reply to try and quote.
        You can also link to another reply rather than using quote by copying the reply number top left, then use the link tab like you did in the old forum to make it clickable such as #675746 which should take you to a post in the reply test thread or type a word rather than the number
        #678200
          Good thinking, Jason
          This will be my first of several
            This is me attempting to quote from another current thread [or do I mean topic?], by quoting its number:
            https://www.model-engineer.co.uk/forums/topic/comments-constructive-on-the-new-forum-software/page/7/#post-677994
            #678236
              An observation …
              I found it impossible to sign that ^^^
              because the BLOCKQUOTE doesn’t get closed
              #678243
              Martin Connelly
                @martinconnelly55370
                On Michael Gilligan said
                An observation …
                Takes a bit of fiddling around to use. When editing the fonts used in the quotes and in the comments look to be the same but when it is submitted there is a glaring difference in the fonts.
                Martin C
                #678245
                  Here’s a not quite randomly selected snippet from an old thread:
                  First as a simple paste:
                  Michael’s ‘This is the most helpful document that I have found so far: **LINK** ‘ made this morning’s coffee delicious.
                  ‘Automated optical inspection for the runout tolerance of circular saw blades’ describes a computerised optical jig for measuring radial and axial run out, repeatable to 2µm. The 2012 paper says the jig is innovative in that existing saw inspections are point contact methods, unreliable because the point wears out!
                  and now using the Quote facility:
                  #678247
                    Notes:
                    1. In both versions the **LINK** has downgraded to simple text
                    2. In both versions, the italic formatting of some text has been discarded
                    3. I still can’t see how to exit the BLOCKQUOTE … but it appears that Martin can
