TEST THREAD
TEST THREAD
Viewing 25 posts - 51 through 75 (of 131 total)
  • #298328
    peak4
      @peak4
      Title1
      Title2
      Title3
      Title4
      Centre justified
      Centre justified
      Centre justified
      Centre justified
      RHS
      RHS
      RHS
      RHS
      Well that seemed to work as a pasted table from Word, using the "Paste from Word" radio button at the top.
      Preserves the three different justifications as well, at least in the preview, shame the table is too wide on the submitted post.
      Title1
      Title2
      Title3
      Title4
      Centre justified
      Centre justified
      Centre justified
      Centre justified
      RHS
      RHS
      RHS
      RHS
      1.0 cm column width
      a
      b
      c
      d
      1
      2
      3
      4
      5cm Table width
      a
      b
      c
      d
      1
      2
      3
      4
      15cm table width
      a
      b
      c
      d
      1
      2
      3
      4
      14cm table width
      a
      b
      c
      d
      1
      2
      3
      4
      Looks like you need to specify the table width rather than the column width
      Edited By peak4 on 15/05/2017 22:00:54
        Just testing imgur
        Edited By JasonB on 11/09/2017 10:25:14
        #316723
        Tony Dimnick
          @tonydimnick84271
          newbie here!! TEST
          #316758
            Posted by Tony Dimnick on 12/09/2017 17:06:16:
            newbie here!! TEST
            Lucky to get that past the mods! Almost as good as 'I am not a spammer'.
            Tony Dimnick
              @tonydimnick84271
              Hello Niel!
              I've been reading topics and comment here. This forum is awesome! Thanks for accepting.
              #316845
              colin brannigan
                @colinbrannigan54160
                I failed to post a photo so will go to the shed…………………sad
                Colin
                Edited By colin brannigan on 13/09/2017 16:37:54
                #325455
                  Testing embedded code to see if indentation is honoured
                  #include
                  #include
                  #include
                  #include "getword.h"
                  #define MAXWORD 128
                  typedef struct bintree
                    struct bintree *lower;
                    struct bintree *higher;
                    char *word;
                    int count;
                  } Node;
                  //typedef struct bintree Node;
                  Node* addNode( char* word, Node *tree );
                  void printTree( Node* tree );
                  int main(int argc, char *argv[])
                    char word[MAXWORD];
                    Node *first = NULL;
                    while (getword(word, MAXWORD) != EOF)
                      first = addNode( word, first );
                    printTree( first );
                    exit(0);
                    if ( tree == NULL )
                      tree = ( Node *) malloc ( sizeof tree );
                      tree->word = strdup( word );
                      tree->count = 1;
                      tree->higher = tree->lower = NULL;
                      return tree;
                    else
                      if ( strcmp(word, tree->word) == 0 )
                        tree->count++;
                        return tree;
                    if ( strcmp(word, tree->word) > 0 )
                      tree->higher = addNode( word, tree->higher );
                    else
                      tree->lower = addNode( word, tree->lower );
                    return tree;
                  Back to normal?
                  Comment :  Success, but not straightforward.  It appears that the forum editor honours embedded HTML tags indirectly via the edit button.  Note font changes to non-proporttional
                  Edited By SillyOldDuffer on 04/11/2017 19:48:30
                  Edited By SillyOldDuffer on 04/11/2017 19:49:24
                  Edited By SillyOldDuffer on 04/11/2017 19:51:39
                  Edited By SillyOldDuffer on 04/11/2017 19:56:35
                  #325457
                    This time using Plain
                    One two three
                       FOUR
                          five
                              six
                    Normal
                    Comment.  PLAIN works too.
                    Edited By SillyOldDuffer on 04/11/2017 19:54:20
                    Edited By SillyOldDuffer on 04/11/2017 19:55:25
                    #342176
                    Brian Sweeting 2
                      @briansweeting2
                      Just a forum date test post.
                      #356319
                      Neil van Zyl
                        @neilvanzyl
                        Another new member that needs to post something in order to see the contact details on an ad.
                        #360772
                          :dark1:
                          #360773
                            Good grief! That worked…
                            #370026
                            peak4
                              @peak4
                              Still Reasonably Tidy
                              Finally one that works, been trying to work out how to add a link or embed a flickr photo.
                              For the one above, navigate to your flickr album, click "Share" and copy the "embed" code.
                              Place into your forum post by using the "embed media" icon; the one next to Youtube.
                              Edited By peak4 on 02/09/2018 12:23:25
                              #376809
                                Having just been enlightened by Neil's mention of the 'remove formatting icon' …
                                I am hoping to kill a smiley:
                                Nope … doesn't work
                                The damned things are invicible !
                                 … This one was inserted using the Plain Text icon !!!
                                Edited By Michael Gilligan on 20/10/2018 16:46:24
                                Edited By Michael Gilligan on 20/10/2018 16:52:00
                                Edited By Michael Gilligan on 20/10/2018 16:53:49
                                #381073
                                Douglas Butler 1
                                  @douglasbutler1
                                  Hi Guys,
                                  This is just a test posting. am completing a part-built Plastow Burrell 4 1/2" at a positively glacial speed tackling the spoking of the rear wheels…..
                                  #387434
                                  John Kingston
                                    @johnkingston58595
                                    how do I gain access to the classifieds info
                                    #387630
                                    Ian S C
                                      @iansc
                                      Usually after you have joined in with some postings in the forum, maybe a question, or suggestion about some topic you have interest in. I think the idea is to have new members with interest in one or more of the subjects on the forum. Welcome aboard John. PS one of the moderators will probably pick up on this and tell you the real story.
                                      Ian S C
                                      #387676
                                        Posted by John Kingston on 24/12/2018 13:50:25:
                                        I takes a few postings which need to be approved by moderators who were a bit distracted recently
                                        #441796
                                        peak4
                                          @peak4
                                          A test from another thread
                                          5130-12-145-6396 to see if it changes to skype
                                          nsn 5130-12-145-6396
                                          Well that seemed to work OK, using Opera on W10, but I don't have Skype as a browser plugin
                                          Edited By peak4 on 15/12/2019 21:12:53
                                          #441801
                                            Posted by peak4 on 15/12/2019 21:08:51:
                                            Now see if you can edit it back to plain text, Bill
                                            Gray62
                                              @gray62
                                              Posted by Michael Gilligan on 15/12/2019 21:26:12:
                                              I just copied then pasted as plain text, using Chrome on a Mac, OS Mojave. I use Skype all the time, never come across this type of issue before, odd behaviour.
                                              Gray
                                              Edited By Gray on 15/12/2019 22:31:11
                                              #441825
                                              peak4
                                                @peak4
                                                Right just been having a quick play; I don't know how Michael managed to convert the plain text in my previous post to Skype hyperlinks when he quoted it, or even if it was intentional.
                                                All the following is using Opera on W10; both at latest builds.
                                                Highlighting the blue hyperlink, on Michael's quote, then Control-C to copy and Control-V to paste gives the following 5130-12-145-6396 again reproducing a hyperlink as expected.
                                                Highlighting the same hyperlink and using the immediately appearing context menu to copy, followed by Control-V gives the same reproduced hyperlink 5130-12-145-6396
                                                N.B. Right Click "Copy", followed by Right Click "Paste", throws up an error.
                                                (I'll hopefully come back to illustrate that in a moment after posting this, as the error locks up this posting/editing window.)
                                                Right Click "Copy Link Address" then Control -V gives this in plain text, which explains what's behind the link. tel:5130-12-145-6396
                                                Somehow "tel:" has been previously added between my original post and Michael's quote of it.
                                                Right Click Link address, (from Michael's quote of my post), and Right Click Paste, again throws up the error message.
                                                #441826
                                                peak4
                                                  @peak4
                                                  Having now check that what I typed is what has been displayed.
                                                  I tried to copy the hyperlink and right click paste, as mentioned above.
                                                  I receive the following error message, which I've had to type in manually as I couldn't copy it.
                                                  "Press Ctrl-V to paste. Your browser doesn't support pasting with the toolbar button or context menu option."
                                                  This is followed by a blue underlined X, which appears to be a hyperlink
                                                  The error message and blue X only show for a few seconds and then time out and vanish, so it doesn't actually lock up the window as I previously thought. The error does however appear over the first couple of lines of text in the posting window, which means that you can't read it; it's on a clear background, so superimposed itself on the previously typed text, making both ones own typing, and the error message illegible.
                                                  edit Further text added.
                                                  Next "Right Click" on the Blue X in the error message and "Copy Link Address"
                                                  Right click "Paste" just throws up the same error message, however Control-v gives  javascript:void(0)
                                                  Edited By peak4 on 16/12/2019 10:35:14
                                                  #441828
                                                    Posted by peak4 on 16/12/2019 10:23:16:
                                                    For the avoidance of doubt, Bill … Michael did nothing to your previous post, it was [and is] displayed on my screen with hyperlinks.
                                                    Edited By Michael Gilligan on 16/12/2019 11:15:27
                                                    #441834
                                                    peak4
                                                      @peak4
                                                      Wow, that is weird, Perhaps clumsily worded; I'd really meant Michael's computer doing odd things. smiley
                                                      I'm guessing it's something to do with your browser, or a plug-in. What I posted, and the way it's displayed is different at my end, (and presumably for most others on the forum), to what shows on your screen.
                                                      Some of what I typed is hyperlinks, as seemingly generated at your end, some is plain text, which seems to have been converted by your PC to a hyperlink.
                                                      I can well understand why my words, as seen on the page, by you must be confusing.
                                                      In particular, see my comments on the third screenshot, relating to the insertion of tel: thus converting it to a hyperlink. I suspect it's something in your browser/PC, rather than the forum software, unless your system has hidden control characters, which are subsequently interpreted by the forum software
                                                      What browser are you using? I'm on Opera for normal use, but also have Firefox, Chrome, Avast Secure Browser, and Maxathon. I also use Pale Moon on the other PC sometimes.
                                                      I'll try opening this thread on them in a bit, but off out to work on the Disco whilst the sun's out.
                                                      Here you go;
                                                      Edited By peak4 on 16/12/2019 11:37:11
