This engine seems to be running on compressed air. My Triple does not. What pressure are you using?
Did you follow Stuart advices about timing compound engines? Nice work!
Giovanni arch.gsorrentino@libero.it
I noticed quite a difference when running my triple on air to steam. The ratio of the steam expansion is different to the air. I found on mine that the first cylinder on air was doing all the work when using air and that the relative timing of the three cylinders needed to be set different when steam is used.
And also thanks for illustrating the method, because I ran my little traction engine on air for the first time last week, and I didn’t know how to put the video up.
Author
Please log in to reply to this topic. Registering is free and easy using the links on the menu at the top of this page.
