Tender materials
Tender materials
Home Forums Beginners questions Tender materials
  • #43529
    Dave Jones 1
      @davejones1
      just a quick question.  Due to the cost of brass, I was thinking about making a tender body from steel (then painted inside and out) is there any reason why I should not do this?  (i.e. will it eventually rust)
      Dave Jones 1
        @davejones1
        #43544
        Ian S C
          @iansc
          I don’t know much about model locos,but maybe you could get it galvanized.
          #44348
          PETER AYERS
            @peterayers98304
                a friend of mine has a loco which is quite a few years old, it has a steel tender painted indide with bitumen paint and there is no sign of rusting. Hope yhis helps
                    Petera
            #44356
            Laurence B
              @laurenceb
              I’m building the tender for a Don Young Class 2 at the moment and have used brass sheet for the tank,but I can’t see any reason not to have made it in steel.It certainly would have been a lot cheaper!
              A member of the club to which I belong,recently completed a Class 2,with a steel tender tank.After every running session he dries out the inside of the tank with a hair drier (I’m not sure his missus approves or even knows!) He reports no problems with rusting.
              I did read somewhere of a model engineer who coated the inside of his tender tank with a resin compound used for the restoration of old and rusty petrol tanks of vintage cars and motor bikes.
              #44361
              IanT
                @iant
                Dave,
                A slightly different suggestion would be to make the tender from stainless steel. You can then use silicon to seal any riveted joints – or if you can TIG weld (or know someone who can) then even better, weld it up. I have a tender in stainless welded up as per the latter suggestion and it is a nice solid job.
                Not sure where the material from my existing tender came from – but I have some very nice stainless steel ‘kick plates’ that came off the bottom of some office doors being replaced by a local company. They would certainly fit the bill for a 3 1/2″ engine – and probably most 5″ locos.
