Telescopic Gauges – Technique?
Home Forums Workshop Techniques Telescopic Gauges – Technique?
  • #611532
    Swarf, Mostly!
      @swarfmostly
      A bit of a personal history for starters:
      My sandwich course, 1954-1958, included twelve months factory attachment of which the first few months were spent in the Trainee Modelshop. (Question #1: why was it called a 'modelshop' ? ) I made some BA spanners and a Browne & Sharpe toolpost spanner, some toolmakers' clamps and a scriber and centre punch or two. They can't have turned out too badly – one of the toolmakers' clamps was nicked!
      Subsequently, such workshop skills as I have, have been built up, patchwork fashion, relying on books, live examples and, recently, YouTube videos and lots of trial and error along the way.
      One blank area in the patchwork has been hands-on experience with using the telescopic gauge to measure bores. I've never tried it.
      I've watched the famous YouTube gurus inserting the telescopic gauge into the bore with a forward lean, pulling it past 'top dead centre' and then measuring it with a micrometer. I presume that the gauge is set with just sufficient tightness to hold the moving arm still but not too much to prevent the arm moving within its mate to adopt the diameter of the bore.
      But, question #2, do they then tighten the handle to prevent the closing force of the micrometer from altering the reading?
      Question #3, how is tthe technique altered if the depth of the bore is, say, only just sufficient to admit the head of the gauge?
      I know that attaining this sort of skill is best achieved with the hands-on aid of a mentor; mentor performs operation, learner performs operation, sequence repeats until both achieve the same reading. I don't have that opportunity but I do have to machine a spigot to fit a recess (think chuck + backplate) and there'll be no second chance. I have mounted chucks on backplates in the past by just very carefully taking off less and less until they fit. I'd like to have a bit more control this time.
      I look forward to members' comments. How do you do it?
      Bestt regards,
      Swarf, Mostly!
      P.S.: I do have a digital caliper gauge.
      Swarf, Mostly!
        @swarfmostly
        #611536
        old mart
          @oldmart
          I find they are fairly accurate, +-0.001" mostly, but they vary in quality which can affect their "feel". If I can, I use the Moore & Wright ones, they are smoother than my cheap set. They can be dismantled and the 45 degree ends made smoother, many people have done this mod.
          My standard method is to compress and lock the gauge before putting it in the hole. Then unlock with the gauge handle tilted relative to the axis of the bore and then lock just enough to hold the setting. Then rock the gauge (I prefer having the ends in a vertical plane if possible) past the tightest point and remove. Careful measuring without changing the size last. Repeat for critical measurements to prove matching figures.
          Practice on known bore sizes if possible, I have a ring gauge, but with care a locked micrometer can be used, but you need to be square each time with parallel faces.
          #611613
          David George 1
            @davidgeorge1
            Old Mart is correct in action but I do a few extra bits in my measuring action.
            Wipe the bore to be checked firstly. Next check the gauge is free and springy with no sticking and smooth action. Put in the bore at a slight angle with the gauge unlocked and tighten to lock. Next move the stem of the gauge perpendicular to the axis once only over center till you feel the gauge us free. Remove from measured item and carefully measure the gauge with a micromiter with care to not to over pressure the gauge and move it. Repeat all actions and compare sizes with first try.
            I hope this helps.
            David
            #611615
            Neil Lickfold
              @neillickfold44316
              I tell people to get a ball bearing. Measure the ID with your gauges, and keep trying until you get the same diameter as the bearing. Use the Outside of the bearing to practice the feel for the correct diameter of the bearing outer. Eventually you will figure it out and then be able to measure with confidence with both the outside mic and with the tele gauge.
              #611627
              Ramon Wilson
                @ramonwilson3
                I do as others have said rocking the lightly nipped up gauge across the diameter once to set the guage. I always tighten it slightly before measuring.
                When measuring I support one end of the gauge on the micrometer anvil then rock the gauge slightly as the mic is closed to feel for contact as it passes over centre so to speak. Always repeat several times to get a mean but never rock across the bore and back to set it – just the once only
                Neil's tip of using a bearing is a good one – not heard that before – but a good way to establish to yourself you are getting the right kind of feel and measurement skills from an exact known source.
                Tug
                #611628
                roy entwistle
                  @royentwistle24699
                  Takes practice, and plenty of it. Just like anything else really.
                  #611632
                  Hopper
                    @hopper
                    And on holes 1/2" and under you are better off using ball gauges. Much easier to set, giving more reliable result for the inexperienced (and the out-of-practice experienced too!).
                    I usually rock T gauges in two planes. First — with the T at an angle — side to side to make sure the T gauge is sitting dead centre in the circle of the hole, then carefully rock it over centre lengthways once to get the size. Same technique in the mike to get careful measurement without moving the plunger of the T gauge.
                    It does take practice and "feel" and if you are not doing it all the time, you do get rusty. These days, proper inside mikes and dedicated bore gauges are not that expensive so are worth looking into.
                    Edited By Hopper on 29/08/2022 10:13:09
                    #611634
                    Mike Poole
                      @mikepoole82104
                      I insert the gauge in the bore and lightly nip, straighten the gauge to close it down to size. The gauge should not be able to rock side to side, if it does it is undersize. I then tighten and check it does find a point where it touches without excess force, if you need too much force then it is probably oversize and if there is no sweet spot then you are undersize. Definitely a tool that developing a feel for will help with accuracy, some care with the mic is also required and using the ratchet should avoid compressing the gauge.
                      #611638
                      Steve Crow
                        @stevecrow46066
                        I find that using a micrometer stand makes it a lot easier when measuring bore gauges.
                        Steve
                        #611643
                        Circlip
                          @circlip
                          Ask ten 'Engineers' the same question and you'll get ten different answers, the same applies to 'Feel'. Some rely on a certain number of clicks of the ratchet stop but that doesn't allow for the speed of spinning the spindle closed. Doubt with his skills Ramon would really need the extra 'nip' to ensure not pushing the bar back. Wonder what the blind machinists (NO slight OR pun) comparison measurements are using a Braille mic? The ability to get a 25mm measurement on a 25.1mm block is extremely easy for some and especially winding the toolroom foreman up "Can i borrow the 1-2" adjustable spanner.
                          Feel is an acquired thing that applies when fitting parts together and don't even start to introduce tolerances.
                          Regards Ian.
                          #611647
                          roy entwistle
                            @royentwistle24699
                            How many people use calipers these days. When I started my apprenticeship in 1950 I was expected to have inside and outside calipers, a square and a six inch rule, and know how to use them. We were expected to have our own tools because it taught us to respect them. You never borrowed tools off another workman. Tools could be bought at the works shop, at a discount and paid for weekly.
                            #611649
                            Swarf, Mostly!
                              @swarfmostly
                              Posted by Circlip on 29/08/2022 11:32:19:
                              Regards Ian.
                              Good afternoon, Ian,
                              Thank you for your post. (Thank you to all other posters as well but I want to reply particularly to Ian. )
                              I started this thread with some trepidation because I do appreciate that 'feel' is not easy to communicate using the written word. For that reason, I am grateful to everyone who has bravely made a contribution.
                              However, my opening post does contain three specific questions. #1 is a matter of interest but is a side issue from my main enquiry. Several contributors have answered #2 but nobody has addressed #3. The task I have before me does involve a recess that is too shallow to permit 'rocking ' of the telescopic gauge.
                              Thank you again to everyone who has commented and I look forward to still more contributions.
                              Best regards,
                              Swarf, Mostly!
                              #611654
                              Anonymous
                                I don't know the answer, as I never use telescopic gauges. Up to 1/2" I use ball gauges, as suggested by Hopper. From 1" to 32" I use internal micrometers. For the awkward 1/2" to 1" range I use test pieces, either from stock material or ground to a specific size as needed.
                                #611668
                                noel shelley
                                  @noelshelley55608
                                  Hi Swarfy, For test pieces to practice on, pop round to your local bearing supplier and ask for a few old bearings – they will normally have plenty and be glad to give you some. Noel
                                  #611680
                                  old mart
                                    @oldmart
                                    The bores of old bearings do make useful practice pieces for measuring as they are made very close to the exact size. I have a collection of mostly new bearing races up to 6" bore which can also be used for milling parallels. Not only testing telescopic gauges, but also to see how close the inside ears of calipers are. My Mitutoyo's and Tesa can measure inside to 0.001" reliably, but I would have to try out the cheap digitals before trusting them.
                                    #611681
                                    larry phelan 1
                                      @larryphelan1
                                      Regarding your backplates, nothing wrong with that method, it,s the way I made mine, teeny bit at a time.
                                      Result—snug fit !
                                      #611682
                                      larry phelan 1
                                        @larryphelan1
                                        Result—snug fit !
                                        I do have a set of those gauges [how good they are is another question ] but I dont remember the last time I used them, never really got the hang of them.
                                        #611683
                                        Ramon Wilson
                                          @ramonwilson3
                                          Sorry for the omission SM.
                                          Shallow depth bores are difficult at best. When boring out the bearing housings on the IC engines that very situation arises Though I 'size' the hole with a accurately turned plug gauge I do use the tele-gauges to get me close.
                                          In this case I try to hold the gauge as carefully as possible across the diameter of the bore with it just loose then gently nip up. i.e. no rocking though centre. This can sometimes give a false reading due to potential movement, albeit very slight, on the tightening action but several readings will get you pretty close.
                                          I had a set of Moore and Wright gauges and later bought the double sided versions – Draper I think. They were as someone said a bit hit and miss and 'draggy' but an hour or so taking them apart and stoning all sliding surfaces transformed their use. I sold the M&W ones on.
                                          Best – Tug
                                          #611693
                                          peak4
                                            @peak4
                                            Swarf Mostly, re your #3
                                            I'm not sure what you mean by Digital Calipers on your p.s. in the first post.
                                            I always struggle a bit with smaller internal measurements, up to a couple of inches or so; or at least I always think I do, so resort to trying to take measurements by two different methods and comparing them.
                                            I'm fortunate in having all sorts of measuring instruments that I've picked up cheaply over the last 30-40 years, several of which are intended for internal distances.
                                            If your Digital Calipers, are of the sliding 6" scale type, like vernier calipers, but digital, then yes I have them in vernier, digital and dial varieties, as well as conventional internal micrometers, and a 3 point bore gauge.
                                            By far the easiest instrument I have for bore/internal measurements are a couple of sets of MPJ dial calipers, which came via ebay: I most commonly use a set which covers about ½" to 1¼"
                                            I think I paid about £20 delivered, but they regularly show up in the £30-40 price range.
                                            They are similar in style to these eye wateringly expensive Mitutoyo ones from Machine DRO
                                            https://www.machine-dro.co.uk/mitutoyo-internal-dial-caliper-0-4-1-2-0-0005-209-352
                                            Even though mine are old, they are easy to use and repeatable to less than a thou with care, and ideal for shallow bores, short linear steps etc.
                                            Bill
                                            #611736
                                            Circlip
                                              @circlip
                                              Sorry for the omission SM. My induction/enslavement was only a couple of years after yours and was instructed/directed by quite a few sexagenarians – thankfully, boy, those guys knew their onions.
                                              As Ramon has stated, in anticipation of a shallow bore measurement , first job would be to turn a plug gauge, the diameter of which can be easily checked and then 'Creeping up' to the required bore.
                                              Regards Ian..
                                              #611750
                                              Emgee
                                                @emgee
                                                Ref #3 from OP For shallow bores and grooves, like Bill I use Dial calipers and a mic to check over the ends when the dial reads as the bore/groove indicated.
                                                Sometimes it's better to set the mic to the dimension required and check the reading on the caliper dial so you have a target to get to.
                                                As Bill said these do come up for sale fairly often and are well worth the investment as they are also useful to check any bore is parallel.
                                                For smaller than 12mm diameter holes/bores I find ball type gauges and a mic give accurate readings but only with practise as is the case with telescopic gauges.
                                                Several other useful methods for measuring bores can be seen in my Photo Album. (Internal Measuring Devices)
                                                https://www.model-engineer.co.uk/albums/member_album.asp?a=35959
                                                Emgee
                                                Edited By Emgee on 30/08/2022 11:42:00
                                                #611753
                                                Hopper
                                                  @hopper
                                                  Posted by roy entwistle on 29/08/2022 12:33:58:
                                                  i still use them from time to time. (The old spring calipers, not vernier or digital.) Actually handy for the question in hand about measuring the diameter of a shallow recess, then measure the calipers with a micrometer.
                                                  We were issued with them as apprentices in the 70s but I rarely remember ever using them much. But prior to about WW2 or a bit after, much reasonably precision work was done with calipers and six inch rule, as you say. Final fit and finish would be done by direct comparison with the mating part. I know they were my old man's go-to measuring tool on the lathe. He was an apprentice of the 1940s.
                                                  #611780
                                                  Rod Renshaw
                                                    @rodrenshaw28584
                                                    Lots of useful advice on techniques for telescopic gauges in the posts above. In one of his books Tubal Cain gave some advice for using spring calipers ( plain ones, not the screw adjusted ones) which he regarded as potentially very accurate. He was writing 50 odd years ago but the advice still seems relevant for those using plain calipers.
                                                    First adjust the calipers to roughly the size needed. Then try for fit.
                                                    If the caliper opening is too large, hold caliper by one jaw, near the pivot, and tap the other jaw on the vice, and try again.
                                                    If the opening is too small, hold caliper vertically by one jaw, jaws up and pivot down, and tap the pivot vertically downwards on the vice, and try again.
                                                    It really works and makes it fairly easy to make tiny adjustments with a very simple piece of kit..
                                                    Rod
