I found the tricky bits were eyeing up things so the gauge was exactly across the diameter and nipping up the lock screw without disturbing things.
The domed ends on the spring loaded bars reduce any errors due to the gauge not being exactly across the diameter. If working to the usually accepted ± a thou (ish) accuracy you have to be pretty sloppy to be out of range. Being short sighted in one eye and long sighted in the other I have an excellent eye for level at a yard or more but it doesn't work so well close up. Visual alignment with the lathe bed got me going but, having got the knack, I now just do it.
Nipping up the lock without disturbing the setting is another knack. Try to do it too tight and the gauge will almost certainly move. Too loose and it will spring out as you withdraw it or shift under the micrometer. The first, cheap and rather rough, set I had didn't help. Over strong springing and rough turning threads made it hard. The well used, well cared for, M&W set I now use are silky smooth and so much easier. Nicely run in I think and almost certainly better than new. Was given a set of three that appear to be almost unused and they aren't quite as nice, just really smooth rather than silky.
Holding the gauge and micrometer freehand to make the measurement is another knack. Especially with the big ones. I frequently cheat and use a micrometer stand.
I'm confident to within half a thou error band if need be. But the care and concentration isn't routine.
