Telescope Mount: DIY Azimuth Bearing Suggestions?
Home Forums General Questions Telescope Mount: DIY Azimuth Bearing Suggestions?
  • #520513
    Dr_GMJN
      @dr_gmjn
      All, I've been making a Dobsonian telescope mount for my long neglected Meade 10" Starfinder. The original equatorial mount was hopeless, because it was designed for a smaller telescope.
      Anyway, with reference to some online builds, I drew up some MDF shapes for a tube frame and a base. In theory, it can all be pretty much balanced over the azimuth axis in order to avoid any significant tipping moments. A friend cut it all out on his CNC router, and it all went together OK.
      I designed and made some 3D printed quadrants with adjustable clamps to go around the tube to stop it falling through the tube frame. This also allows the tube to be rotated in-situ to get the eyepiece in the right place. The contact faces of the tube frames will eventually be lined with felt to make it all look and feel nice.
      The altitude bearings are machined Teflon blocks, screwed into 3D printed holders. The trunnions are CNC routed hardwood blanks, finished in the lathe. They need some textured Formica edging wrapping around them to reduce stiction (as online sources suggest), but so far so good:
      The aluminium discs will eventually have a couple of small Teflon rubbing blocks next to them to keep everything aligned laterally.
      The issue I've go is the azimuth bearing. The same online sources again suggest using Teflon pads, or furniture glides, running on an old vinyl record; the grooves in the record apparently reduce stiction. However, the base of mine seems way too big for this to ever work smoothly. Here it is with a c. 400mm diameter cake turntable on the base (the white outline is filler due to an error when CNC routing I think – doesn't have any effect of function):
      Since I could fit a slew bearing of up to 400mm diameter on that footprint, I can't see a 12" (300mm) diameter record being anything like stable enough.
      Even if I stole the ball bearing slew ring from the middle of the cake turntable for the primary support, and used Teflon blocks outboard of that, for stabilisation, I think any slight out-of-balance of the top half would cause enough friction to make rotating the base very jerky, plus I'd need a continuous ring of something with low stiction for the blocks to run on.
      So what I'm after is suggestions as to how to make, or adapt, something into a c. 400mm diameter, low friction slew bearing.
      I thought of a central hub, with axles radiating from it with small wheels on their ends, but again the issue is finding something very smooth for the wheels to run in.
      Thanks.
      Dr_GMJN
        @dr_gmjn
        #520632
        Brian H
          @brianh50089
          I'm no use at all on this one but just thought it would be good to bump it up the list in the hope that someone helpful sees it.
          #520638
          Bob Mc
            @bobmc91481
            Hi Dr GMJN….
            This may be helpful, https://stellafane.org/tm/dob/resources/bearnings.html
            seems that after some experimentation that kitchen laminate was a good candidate.
            I have made a vertical azimuth telescope bearing using the material that my wife has for doing oven cooked chips, I don't know the name of it but its a golden cloth type material, in my application it slides on a metal shaft however you can't glue it so it would have to be held in place at the edges for a Dob.
            Bob.
            #520641
            Cabinet Enforcer
              @cabinetenforcer
              eBay search for lazy Susan bearing.
              Not that dear and available in 14" size or even bigger.
              #520646
              Chuck Taper
                @chucktaper
                First off that's a real nice job. Put some effort into an "Equatorial Dob" myself… haven't given up yet but….
                Have you considered using a "Lazy Susan" type bearing?
                Available in many sizes and qualities.
                Extreme precision in a Dob. is one of those diminishing return things. (my own experience only)
                Looking forward to some pictures of the final instrument!!
                Frank C.
                #520674
                Dr_GMJN
                  @dr_gmjn
                  Thanks guys that's great. I didn't know that Lazy Susan bearings went up to that diameter.
                  If I can source one, I might make the base itself from a triangle of dimpled formaica kitchen worktop, use the Lazy Susan bearing in the centre to take the majority of the z-loads, and then make three height-adjustable teflon pads in light contact with the Formica base, purely as stabilisers to keep the bearing races parallel.
                  That should do it.
                  #520680
                  Dr_GMJN
                    @dr_gmjn
                    Just to add – I found aluminium/ball bearing type Lazy Susan bearings up to 1m diameter on Amazon just now….
                    #523882
                    Dr_GMJN
                      @dr_gmjn
                      Posted by Brian H on 18/01/2021 09:07:35:
                      Thanks Brian – it worked!
                      #523884
                      Dr_GMJN
                        @dr_gmjn
                        All,
                        I finished the telescope mount, a brief account of what I've ended up with is here:
                        DIY Dobsonian Telescope Mount | Model Engineer (model-engineer.co.uk)
                        Thanks again for the advice.
