Agree with MichaelG about the Ebay seller, I have cleaned him out of my favourite filled PTFE (60% bronze-filled) but it difficult get the size(s) that you are looking for. To buy this stuff new from a stock supplier is prohibitively expensive so buying offcuts is a good solution. My need was for 2 different sizes – 30mm O.D. tube and 8-10mm rod. I managed to get some 30mm O.D. rod but of course machining that down to provide some thin 30mm O.D. seals was a criminal waste of material. But I had no choice
For the small diameter rod I cut up and turned a heavy walled section of 5" tubing, the square-ish sections thus produced provided me with nearly 2-1/2 metres of 90mm-long rods at 10.5-12.5mm diameter. Perfect, and a lot cheaper than buying that as new stock.
Edited By Chris Heapy on 23/04/2013 16:48:09
Edited By Chris Heapy on 23/04/2013 16:48:52
