Thanks to all who have replied.
Basically , I want to make a fitting to attach a strap to the neck heel of my beautiful handmade acoustic guitar.
The normal method of doing this is to screw a strap button into the side of the neck heel but for many reasons, not least of them aesthetic, I don't want to do that.
A much more elegant solution is to have the fixing in the base of the heel, but the problem with that is that it throws the balance of the guitar off …it wants to cant away from the player when it is held in the strap, and what you want to occur is the exact opposite…the guitar should want to lean back into the player's body.
So what I have come up with is a solution whereby I will have a Z shaped stainless steel bar, 3mm thick and 12mm wide, with two holes drilled in each of the Z ends. One hole will accommodate the bolt which will fix the Z bar to the underside of the heel,( by screwing into the threaded insert) and the other hole will accommodate the clip on the end of the guitar strap. The length of the Z will be around 2 1/2" …this will give the correct balance, so that the guitar doesn't want to pull away.
I don't think there will be any problem tapping the wood …the neck is made of Cuban mahogany, which is close grained enough to take a thread, but I am constrained by the fact that the base of the heel, which is triangular in shape has quite a small area, so I don't want to remove too much wood.
Thinking about it, there isn't any reason why the internal threaded hole has to be 1" deep…it only needs to be deep enough to accept the M4 bolt, so probably 15mm depth would be ample.
The whole object of the exercise is to enable the fixture to be removed when not in use, and for the fitting to be as discreet as possible.
I am thinking now, in view of the advice above, that there are only two solutions …either tap out the M6 insert to to 3mm or else do as Clive suggested and use solid 6mm rod and knurl it (I would actually file grooves, I don't have a knurling tool).
Hope I have explained clearly enough what I am aiming for , and thanks to everybody again for their help.
Edited By murrmac on 21/12/2013 10:51:45
Edited By murrmac on 21/12/2013 10:52:22
Edited By murrmac on 21/12/2013 11:20:23
