Posted by Paul Scholey on 28/06/2011 21:06:41:
I am tapping in the Lathe, Do spiral flute taps have a flat bottom then? I only have one and it has a small taper but it is the wrong size. Are spiral flutes better for tapping stainless?
Can I completely grind the bottom off a hand tap or does it have to have some taper?
Some of my spiral flute taps have a flat bottom, some have a small cone, which could be ground off.
Spiral flute taps are not designed especially for stainless steel, but are designed specifically for tapping blind holes. The helix angle and coating will determine which materials are best for a given tap, including but not limited to, stainless steels. Spiral flute taps generally cut a full depth thread within 1-2 pitches, in one go, as opposed to the 2 or more pitches on a bottoming hand tap.
As an aside the cones on the bottom of some of my spiral flute taps would not be problem if the blind hole was drilled, rather than being flat bottomed.
I would suspect that if you grind all the taper off a bottoming tap you’ll just end up chipping the teeth. Either way a bottoming tap is intended to clean up a partially formed thread, not cut one in a single pass.
What grade of stainless steel are you using?
Edited By Andrew Johnston on 29/06/2011 11:14:54
