Hello,
Thanks for the idea, The O/D of the thread is 1/4" UNF, The hemisphere on the tappet adjuster is actually the core diameter so a good bit smaller than !/4". By the time the thread has been turned off and a hole drilled in the ball bearing, you are talking of a very small spigot diameter. I am not sure I like the idea for such a small spigot I suppose JB weld may be OK as an adhesive, but the ends of tappet adjusters get a good hammering. I would be afraid that the small spigot would break and that could cause a fair bit of damage
Andrew..
