tapered slots
tapered slots
Home Forums Workshop Tools and Tooling tapered slots
  • #540445
    grimme
      @grimme
      im in the process of making a 24 stop dividing head thingy, (dont know what theyre are called), its a 5" chuck mounted to revolve on a heavy angle plate to be used vertical or horizontal, behind the chuck is a flange with 24 tapered slots cut into which a tapered stop locates, tapered milling cutters are big bucks so im looking for alternatives to buying one? any ideas??
      grimme
        @grimme
        #540446
        David George 1
          @davidgeorge1
          How are you cutting the slots. If you cut them on a dividing head you can rough them out square firstly, then offset the cutter and rotate the plate by a few degrees and cut the first set of side angles. Repeat the operation but opposite offset and angle to complete the angled slots for plunger.
          David
          #540448
          Emgee
            @emgee
            Geoff
            Consider cutting parallel slots but use a tapered plunger key to index in the slot, even with the tapered slots and key it is best to lock the spindle to mill the part being held.
            Emgee
            #540451
            Paul Kemp
              @paulkemp46892
              Use a cheap gear cutter? That will give you a nice slot!  Grind up a suitable single point tool and 'fly cut'?  I think it's a spin indexer by the way.
              Paul.
              Edited By Paul Kemp on 18/04/2021 23:40:25
              #540452
              Pete Rimmer
                @peterimmer30576
                Posted by geoff rimmer on 18/04/2021 22:36:17:
                The plate with the slots is called a masking plate. Used for rapid indexing.
                #540457
                John Haine
                  @johnhaine32865
                  Why slots? Drill parallel sides holes and have tapered pin.
                  #540570
                  old mart
                    @oldmart
                    I wanted to make some special tee nuts for the compound on the Smart & Brown model A and a friend of the museum who did cutter grinding put the required taper on the end of a 1/2" four flute endmill. If you have a suitable donor cutter, then a small engineering firm could probably modify one for you cheaper than a special.
                    Emgee's suggestion of parallel slots with a tapered plunger would work very well if the plunger included angle was about 2 degrees.
