As said above, you certainly need to run the tapered cut with the topslide, not the carriage.
Consider whether you could put a hole in the little end to use with a running centre for tailstock support. If you can, it might still be a fiddle to create clearance to turn the topslide handwheel, but tailstock support would make turning a taper on the conrod a good deal safer.
