Hi ChrisH ,
Mandrels are used almost exclusively for second operation work . That is when the bore is finished to size and some or all other surfaces have to be machined true relative to the bore .
A simple example would be a pulley or gear blank . A common model engineering example would be a cylinder block having end faces skimmed .
Between centres taper mandrels are examples of friction hold mandrels . Work is run along the taper until it locks by friction and after machining pressed off again .
There are many other types of holding device for second operation work – here are just a few :
Parallel between centres mandrel with one step and nut or two nuts .
Fresh turned single ended mandrel with or without nut .
Expanding mandrels and collets as mentioned .
Any type of mandrel with a specific shape turned on it – for instance a Morse taper so that a sleeve can be held by the taper for grinding the outside . Sometimes need nuts to push the work off again .
Machined in place soft jaws .
Note that the simple bore holding mandrels do not require any accurate side faces to exist on work – accuracy of mounting is detemined by bore only .
Where mandrel has register steps and nuts at least one face and ideally two on workpiece have to be machined accurately relative to bore before mounting on mandrel otherwise they may not run true . An example is a loco wheel casting – back and bore premachined before mounting on mandrel to turn the treads .
Regards ,
Michael Williams .
PS: A quite skilled turner in work years ago had some fun when using a between centres mandrel to turn some blanks out of a high Nickel alloy .
As he turned the end faces the initially tight blanks kept migrating along the mandrel . Combination of high expansion alloy and some heat build up was the simple cause – though no amount of coolant would stop the problem entirely .
Edited By MICHAEL WILLIAMS on 07/03/2014 12:44:04
Edited By MICHAEL WILLIAMS on 07/03/2014 12:48:42
