Hi Ian S C.
The material he is using seems to have turned OK when he turned it parallel, so it should turn taper too.
From personal experience, there is a tendency to use very small cuts when taper turning, and this might lead to surface work hardening (depending on material), thus increasing the difficulty. What is needed for final sizing cuts is a tool described in ME sometime in the fifties, which is a front cutting “shearing” tool. This tool for the experts to ponder, is a tool of infinite radius, but with a point contact.
Anyway, this dead simple tool is a great way of making your own wire wool! Get my drift?
I used mine recently to make a less than 0 Morse taper for a rotating centre to fit a Super Adept. seemed to work on that cutting Stainless.
If the moderator agrees I could post a scan, to save you lot having to delve in the archive, if anyone is interested.
chriStephens
