Tap Magic
Tap Magic
Home Forums Model Engineer. Tap Magic
Viewing 23 posts - 1 through 23 (of 23 total)
  • #47553
    Gordon
      @gordon
      Does anyone know of a supplier in Europe/UK that supplies Tap Magic or simialr lubricant for cutting tools?
      Thanks in advance
      Gordon
      Gordon
        @gordon
        Cutting Oil for machine tools
        #47556
        David Clark 13
          @davidclark13
          Hi There
          Arc Euro Trade do a range of cutting lubricants.
          regards David
          #47559
          Gordon
            @gordon
            Thanks David but I can’t find anything on the Arc website or in their catalogue, tried to do a search but came up negative.
            Gordon
            #47560
            David Clark 13
              @davidclark13
              Hi Gordon
              Under grease and advesives.
              I found it here.
              regards david
              #47561
              Gordon
                @gordon
                Thanks David
                But which is equivalent to Tap Magic?
                Which wiuld you recomment to use for tapping and/or threading?
                Gordon
                #47562
                Niloch
                  @niloch
                  It might be worth your while considering TREFOLEX.  (Google for a supplier)
                  #47563
                  David Clark 13
                    @davidclark13
                    Hi There
                    Both seem to work well.
                    regards david
                    #47565
                    Steve Bell 1
                      @stevebell1
                      Hi Gordon,
                      I use Templers Temaxol for tapping and seems to work well. Also recently have been using Castrol synthetic soluble oil and that gives good results for drilling and some turning jobs.
                      A Google search brings up quite a few suppliers of the Temaxol.
                      Steve
                      #47568
                      mgj
                        @mgj
                        DHS tools do it. It seems very good.
                        The new clear ROCOL RTD is very good – less messy than either Trefolex or the dark brown RTD,
                        #47571
                        Tony Pratt 1
                          @tonypratt1
                          Hi Gordon, do you mean “Tapmatic” cutting fluid by any chance? It was a slightly yellowish thin liquid.
                          Tony
                          #47580
                          Nigel McBurney 1
                            @nigelmcburney1
                            Hi  trefolex is good for most tapping,its very similar to the old method of using a mix of sulphur and tallow which was common during my apprenticeship 50 years ago , for very small taps the Rocol rtd paste is very good probably better than the liquid RTD. I do as I was taught ,when using 10 BA taps a drop of spit works wonders.  when tapping cast iron the old method was to use plain tallow.
                            #50866
                            AndyB
                              @andyb47186
                              Hi all,
                              Chronos do a range too:
                              Edited By David Clark 1 on 19/04/2010 17:55:49
                              #50878
                              Terryd
                                @terryd72465
                                Hi Frank,
                                They’re all fine for me the, postings are all as they should be!!
                                Terry
                                #50883
                                Dave Tointon
                                  @davetointon92281
                                  Me too Frank
                                  #50885
                                  DMB
                                    @dmb
                                    Right hand ads r obscuring the posts again.
                                    I DO swear by Trefolex but I often use cleanoils from the kitchen especially rape seed.
                                    Used once for say, chips, got a few bits in it so filter + store in small bottle – very good !
                                    I usually use Trefolex for tapping/Dieing and a well – washed out washing up liquid squeezy bottle tospray drills. Have also used surface cleaning trigger bottles.
                                    Both types deliver far too much and make awful mess so started using 2″ high squeezy bottle with fine spout, ex – hair colour (wifes!). Perfect!!
                                    Have not tried other jollops listed above so cannot comment on their efficacy.
                                    Have tried excess fish oil from small sardine tins and the like but tend to be smelly, goey generally unsatisfactory but do work.
                                    #50886
                                    DMB
                                      @dmb
                                      Sometime ago one of the trade stands at an exhibition was selling tapping jollop in small tubs as used by Trefolex but with no labels. It was the colour of LNER green paint and smelt different ot Tref. Stand holder assured me that labels had fallen off and it was definitely Tref. and it was new formula.  It was useless so binned it. Serves me right I suppose and I genuinely cannot remember who it was. Watch out if you are the guilty one reading this you toerag, because if I see that muck on sale again I`ll buy some and give it to Trading Standards and tell Tref.`s makers.
                                      #50889
                                      Peter Gain
                                        @petergain89847
                                        Hi Moderator,
                                        Please move the adverts from the r/h side. They are obscuring the posts.
                                        Peter  Gain.
                                        #50890
                                        wheeltapper
                                          @wheeltapper
                                          Posted by Peter Gain on 19/04/2010 11:34:05:
                                          Hi Moderator,
                                          Peter  Gain.
                                           It’s that long link for Chronos thats doing it, David normally edits those.
                                          Roy
                                          #50910
                                          David Clark 13
                                            @davidclark13
                                            Hi There
                                            David has been away at the Myford show.
                                            Kelvin Barber is on holiday so a short wait was inevitable.
                                            regards David
                                            #50948
                                            wheeltapper
                                              @wheeltapper
                                              How many goodies did you bring back
                                              Roy
                                              #50950
                                              KWIL
                                                @kwil
                                                This is not a general problem
                                                #50963
                                                Gone Away
                                                  @goneaway
                                                  Posted by Gordon on 19/01/2010 11:34:01:
                                                  might help. There is a “Where to Buy” tab. They don’t explicitly say they have distributors in Europe but they do have a “contact us for the name of your nearest supplier”
                                                  Great stuff …. use it all the time.
                                                Home Forums Model Engineer. Topics
