Tank tracks are made from Chrome Molybdenum steel and are cast.
The track pins make excellent chisels, tough and durable.
They have to be very durable as they carry vehicle wieghts of about 60ton on all types of terrain up to speeds of 40mph.
Tank tracks are of two types, ‘live’ and ‘dead’.
The ‘live’ type have rubber bonded links that spring the track, hence the term ‘Live’.
To keep the tracks flat the pins are hexagonal so as the track goes around the hubs it flexes on the rubber bushes of which there are about five or six in each link.
The ‘Dead’ type of track was the type used on Russian tanks and laid itself flat on the road wheels as it was carried around the hubs. The links were like flat cast slabs and had round pins.
For model purposes the requirements are not so severe as the model is small and light. Modelling the ‘Live’ track will be very tedious as the links would have to be joined with rubber bushes to be lifelike.
The Bren Gun Carrier had quite light tracks of steel and because of the type of springing involved the track was quite loose.
I think perhaps it would be possible to do die castings of track in a white metal, remember you need two or three hundred. Then using a jig, drill them and fit the pins.
Pins are retained with ring clips that are sprung over a taper on the pin into a groove.
There is a washer with a groove that the ring clip sits up against. This helps to retain it in place.
A very tedious project making tracks!
