Tangential tooling
Tangential tooling
Home Forums Workshop Tools and Tooling Tangential tooling
  • #791958
      Not one that I’m supposed to post on here but easy enough to find on the net.
      I could also say that the inserts are useful when you what various internal radii and the **GT ones are also good on many plastics. 😉
      Hollowpoint
        @hollowpoint
        On JasonB Said:
        I could not see a price for the replacement HSS blanks but you can get a box of 10 inserts to drop onto your doormat for £4-5 so that is 40 sharp usable corners. Similar cost for a holder. Diamond holder is £92 inc delivery so possibly cheaper over time as you should be able to get quite a few sharpenings out of a bit of HSS. That is provided you are not cutting chilled castings which will take the edge off your HSS rather quickly.
        Insert is probably more practical when working small diameters with tailstock support. And you can use the inserts in your boring bars so saves having to buy both.
        You can probably gues from above that I have not been tempted to buy or even make one.
        I’m almost all carbide now, probably over 95% of my turning and at least 80% of my milling is now done with insert facemills or solid carbide, that will go up as I work through what HSS cutters I have that are still usable and replace with carbide. Drilling and reaming still HSS.
        I’ve wanted to try one if the tangential holders ever since I found out about them. But like you, most of my cutting is done with carbide. I’d say about 90% for the lathe but less so so on the mill. Maybe 40-50%. I can’t be bothered with the mess and time needed to grind HSS. On top of that, theres absolutely no way I could grind a tip as accurately as carbide.
        #792013
        bernard towers
          @bernardtowers37738
          When you say grind your tip accurately what exactly do you mean?. The basic angles are very forgiving, most of the problems are when grinding screwcutting tools but that comes with practice and a few jigs.
          #792023
          Howard Lewis
            @howardlewis46836
            Carbide tips are marvellous if the material is hard, and can produce excellent finishes.
            But are less tolerant of careless handling or interrupted cuts.
            The advantage of tangential tools is that the HSS toolbit can be sharpened easily, when the shops are closed for the weekend, and can be ground to a specific shape for a particular job.
            Horses for courses.
            Both have their uses.
