T. E. Haynes Hot Air Engine.
Home Forums Stationary engines T. E. Haynes Hot Air Engine.
  • #649186
    Bo’sun
      @bosun58570
      Good morning All,
      A couple of years ago, I built the T. E. Haynes Hot Air Engine, and it ran extremely well using a Trangia meths burner from a camping stove. Admittedly, with the addition of a cooling jacket on the "cold" end of the transfer cylinder.
      Recently, I decided to run it using the attached gas burner. I used a disposable propane/butane cartridge and regulating valve. The result was a very sooty flame, completely blackening the transfer cylinder.
      Would it help if I modified the burner like a Bunsen Burner to entrain and regulate the air/gas mixture?
      I did wonder if the burner jet was a bit on the large side at 1/16" dia?
      Thoughts and comments appreciated.
      I know it's only a basic model, but it has nostalgic memories from making the first one at school 50 years ago.
      Bo’sun
        @bosun58570
        Running it on gas?
        #649187
          More air will give a bluer less sooty flame and 1/16" is massive
          #649188
          Bo’sun
            @bosun58570
            Thanks Jason,
            Any suggestions as to burner orifice size anyone?
            #649189
              small as you can get, something like a No5 which is 0.2mm
              This uses a 0.07mm jet from the smallest Sievert nozzle
              Edited By JasonB on 21/06/2023 11:33:29
            Home Forums Stationary engines Topics
