All my tommy bars for,toolmakers clamps,tailstock die holders,box spanners, etc are made from silver steel,just as it comes no further heat treatment. just cut to length and face off and then turn a small rad,each end,to save your hands, Currently restorng a Ruston Hornsby stationary engine and doing the water cooling plumbing in 3/4 in bsp steel pipe, threading with a 3/4 bsp die in a large tail stock dieholder ,tommy bar for that is 12 mm silver steel.One curious thing I found with tommy bars was the pair of M&W toolmakers clamps I bought during my apprenticeshiop would not take 1/8 in dia silver in the tommy bar hole,and we only used imperial silver steel in those days,later on I found that the holes took 3mm s/steel, and metric steel was in stock a couple of job later, why in those imperial days were M&W making tools that had metric tommy bar holes, 3/32 ins the readily available size down bent easily so 1/8 dia was reduced in dia to fit.
