S.O.D.
You are right on the money regarding the term Enamel, we would all be better off if this term was consigned to oblivion. Historically, the alkyd paints were so far in front of anything else when they appeared that the term enamel was not an unreasonable comparison.
Complicated? I think it all depends on your background, the other man’s technology often appears that way to the outsider. After a lifetime working as a chemist on the resins used to make paint it seems easy to me! But I really struggle with some of the articles in MEW and anything electronic baffles me completely.
Paint technology suffers from two extra complications not found in engineering i.e. meaningless terms like enamel and coach paint, and tradition.
Painting is a hot-bed of traditional ideas, often against all logic. Why would anyone would want to paint something in cellulose paint when modern paints are better in every conceivable way? Presumably because their vehicles were originally painted in cellulose and they want an original-looking finish? Modern finishes are visually indistinguishable from a first-class job in cellulose and if you can't see the difference,what is the point?
I have been retired (gratefully) for 20 years now so I am not up to date with the very latest, especially in Europe (I live in Australia). It was interesting to me that with all the fire/explosive problems of cellulose paints, they were eventually banned on emission grounds. Especially so because the acrylics use similar solvents.
Nick Clarke.
Yes always go to a specialist or risk disappointment later. Also be careful to use products from one brand. If you use one brand of paint and someone else’s thinner for example, you are giving the paint manufacturer an automatic get-out clause if anything goes wrong.
Andy Carlsen
Yes there are many different acrylics (and alkyds, and polyurethanes, and polyesters) and to me it is debatable whether for a layman it is worth acquiring more than a basic knowledge. It is enough to know that acrylics are generally excellent but normally affected by petrol while polyurethanes are just as good or better than acrylics and not affected.
Generally:
I have yet to see a water-based finish that would be suitable for the kind of items that we make.
Becoming popular in Australia amongst hobbyists for high temperature situations is Brake Caliper Paint . This requires mild stoving conditions but is high gloss, durable and as tough as old boots. It is one-pack and I would guess is a polyurethane.
Chas
