Posted by Peter McAtominey on 05/12/2022 14:44:27:
I did look at those and noticed this in the replacement guide:
These are only suitable if you have an MT3 spindle. At the time of writing, ARC were working on a solution for the R8 spindle, which has a different size bearing at the bottom of the spindle.
I was wondering if it was due to difficulty sourcing the bearings or the cost.
Difficulty in sourcing one of the Angular Contact bearing sizes in 2RS (2 rubber seals)form needed for the R8 Spindle.
If you are prepared to experiment on the R8 spindle, you could leave the top bearing on the R8 spindle to be 6206-ZZ or 6206-2RS, or change it to 7206B-2RS (currently out of stock – expected back in, in about a week), and find someone to supply you 7007B for the bottom bearing, noting that it will be open – as not 2RS. Then, incorporate a seal into part 102 Oil Cover (see Exploded Diagram & Parts List) link on this page. I have a spare seal. If you want to try it, call and speak with our Ian and he will send it to you.
Ketan at ARC.
Edited By Ketan Swali on 05/12/2022 15:21:10
