Posted by Dusty on 20/06/2016 08:21:02:
Glass as a lapping plate No No No No No. The lapping plate /lap needs to be softer than the item being lapped. Why? because if not you will push the lapping compound into the component and despite your best efforts you will leave some behind, this will cause rapid wear on your components when they are running. If however you are just using the glass as a backing for fine wet and dry that is a good idea.
Dusty,
Strictly; you are, of course, correct.
There is, however, another thread running at present; discussing 'lapping' [sic] with abrasive paper on a flat surface, so your "however" is probably a safe bet.
Edited By Michael Gilligan on 20/06/2016 08:52:06
