Swindon Wheel Castings
Home Forums Materials Swindon Wheel Castings
  • This topic has 21 replies, 11 voices, and was last updated 9 May 2021 at 15:13 by Howard Lewis.
  • #543547
    houstonceng
      @houstonceng
      Hi Guys
      A fellow Model Engineer has worn out the wheels on his 5” Gauge GWR “Swindon” and wants to know from whom new castings can be obtained. He has tried most of the well known suppliers to no avail. Definitive answer is required.
      Thanks
      Andy
      houstonceng
        @houstonceng
        Obtaining castings
        #543563
        Nigel Bennett
          @nigelbennett69913
          Why not shrink on some steel tyres? Getting blanks flame or laser cut isn’t expensive, and easier than making and fitting new wheels.
          #543583
          duncan webster 1
            @duncanwebster1
            Depending on the size you might be able to get hollow bar (very thick wall tube). Loctite would probably work, there isn't a lot of load/area compared with the wheel axle joint.
            If you go down this route don't make the mistake one of my acquaintances made, he bought a length and tried to part it off. Pay the extra and get it sawn into blanks just over finished thickness.
            #543585
            Former Member
              @formermember12892
              #543593
              houstonceng
                @houstonceng
                Sorry, don’t recognise M E C H forum. Can you direct me to it.
                #543594
                houstonceng
                  @houstonceng
                  Asked on Google and, of course, MECH means the ME Clearing House and I have already asked there as well.
                  #543603
                  Dalboy
                    @dalboy
                    Has he tried the Blackgate engineering catalogue at the bottom there is a list of wheels but you will have to know the size and other information to see if they have a match
                    #543610
                    stephen goodbody
                      @stephengoodbody77352
                      Hi Andy
                      I’m not sure whether the wheel dimensions are the same for the two designs, but I believe that GLR Kennions sells wheel castings for the 5” gauge Keith Wilson 4700 loco. It might be worth contacting them with the question.
                      Best regards
                      Steve
                      #543625
                      houstonceng
                        @houstonceng
                        Posted by Derek Lane on 06/05/2021 23:16:41:
                        I think he’s tried them on the ‘phone. With no computer, he cannot check the list, but I will ask if there was any wheel that could be substituted. AFAIK, it’s a question of crank throw. It appears that 5” Firefly wheels are used now in new builds, but the throw isn’t correct for his Swindon, so he cannot use them. He tends to build using works drawings and that means he has used the correct throw, knowing what he is doing with a King at the moment.
                        #543626
                        houstonceng
                          @houstonceng
                          Posted by stephen goodbody on 07/05/2021 00:01:08:
                          Hi Andy
                          Best regards
                          Steve
                          i know he tried them and they didn’t have the Swindon castings. I will ask him about the 4700. As I am not a GWR Guru, I don’t have a clue about the differences between 47xx and any other GWR loco. Is a 47xx Firefly? Or visa versa
                          #543629
                          Circlip
                            @circlip
                            Muddle Engineers Clearing House.
                            Regards Ian.
                            #543642
                            Former Member
                              @formermember12892
                              #543645
                              Peter Layfield
                                @peterlayfield
                                Thinking of the work involved with new wheels, spinning the exising set between centres and fitting steel tyres would be far easier, and you can easily buy steel thick wall rings to turn up the tyres, think there is quite a bit of useful info on the GL5 website Forum on this topic, they are heat shrunk onto you existing wheels
                                #543708
                                stephen goodbody
                                  Andy,
                                  The 47xx was another GWR 2-8-0, although intended for fast-freight working rather than the hard slog of the 28xx (Swindon). Upon review, the prototype 47xx had significantly larger diameter wheels than the 28xx but I believe a similar cylinder stroke. Hence the crankpin throw will presumably be similar, but I suspect the wheel diameter will present a problem.
                                  I must say that I'm on the same page as many of the other respondents – if your friend's problem is worn treads and/or worn or damaged flanges, and the rest of the wheels and the overall axle assemblies are in good shape, then I would go for the shrink-fit steel tyre solution. In addition to being the most straightforward option from a machining perspective, it would also prevent the need to remove the wheels from the axles, and get the new wheels accurately quartered, and then re-set the eccentrics to suit the new quartering position. It would also presumably be cheaper than buying new wheel castings!
                                  Best regards
                                  Steve
                                  Edited By stephen goodbody on 07/05/2021 14:45:46
                                  #543745
                                  houstonceng
                                    @houstonceng
                                    ..I talked to him again today as we were dismantling our MES for removal to its new site. As an aside, it’s shown us how much junk we saved ‘just in case it comes in handy”, and a lot has gone to the scrappy.
                                    Anyway, when he built the loco, he couldn’t get the correct 28xx wheel castings so used the 5” Firefly castings. They, apparently have a shorter stroke, so the crank-pins are are a bit close to the end of the webs. Now he has worn out these wheels, he was hoping to be able to buy the correct wheels on the basis that “a few more 28xx castings should be available by now”. Apparently not !
                                    if the correct wheels cannot be sourced, he was thinking of putting tyres on the current wheels, but wanted to check if he could source correct ones before going down that route.
                                    Edited By houstonceng on 07/05/2021 18:05:04
                                    #543769
                                    Nick Hughes
                                      @nickhughes97026
                                      Have a chat with Mark Wood Wheels.
                                      He may be willing to scale the Gauge 1 28XX wheel castings he already does, up to 5" Gauge for your friend.
                                      I had my 5" Gauge Late Castle Driving wheel castings from him, after asking this same question.
                                      Nick
                                      Edited By Nick Hughes on 07/05/2021 21:15:36
                                      #543810
                                      Nick Clarke 3
                                        @nickclarke3
                                        A search through the online ME index brings up an item for "Wheel Castings for Swindon (College Engineering Supply)" in volume 155 issue 3764 but I do not have this issue in my collection. The College Engineering Supply website does not list the wheels, but perhaps someone might have this magazine or a phone call could take you forwards?
                                        #543813
                                        Howard Lewis
                                          @howardlewis46836
                                          If it is any help, the 47xx Express Goods 2-8-0 engines had 5'8" diameter driving wheels.
                                          The 28xx Heavy Goods 2-8-0 ngines had 4'41/2" diameter driving wheels.
                                          Found in O S Nock's book on "Great Locomotives of the GWR"
                                          #543901
                                          houstonceng
                                            @houstonceng
                                            Posted by Howard Lewis on 08/05/2021 08:30:06:
                                            My friend Bob, who is the person wanting the wheels, has explained all about GWR Wheel diameters and crank throws. Sometimes I wish I had not volunteered to enquire on t’internet for him.
                                            #543906
                                            houstonceng
                                              @houstonceng
                                              Posted by Nick Clarke 3 on 08/05/2021 07:53:20:
                                              Model Engineer Laser also list balance weights for College or Firefly wheels, and I have passed on the information that CES might do the wheel, to Bob (my friend on whose behalf I was asking).
                                              As many of us have probably found, ycastings for nearly all the MAP plan locos were available back when LBSC and Martin Evans wrote in the Model Engineer. Sadly, a lot of designs now don’t have castings available from suppliers. Case of “not worth stocking them when we only sell one set every millennium”. Trust Bob to build one of them. Castings for Maid of Kent, Simplex, Speedy, Sweet Pea, and similar “fly off the shelf” quicker than they can be cast. Classic supply and demand.
                                              #544059
                                              Howard Lewis
                                                @howardlewis46836
                                                Sounds like a need to follow prototype practice, and fit steel tyres.
                                                A lot less work that having to machine castings from scratch, IF they can be obtained..
                                                The problem may then be finding a large enough lather in which to do the work! But that would be there whichever route is followed.
                                              Home Forums Materials Topics
