Hi Steve .
It Depends on how the tile was made as i think they press them so it could be quite flat .
Set it up in front of a decent light source and lay a known good straight edge (Rule or Engineers square ) across the surface you wish to use .
By starting at one end and carefully dragging it across the surface look for any light to appear between the straight edge and the surface of the tile then do it again at 45 degree increments .
If little or no light appears then it will be flat enough for what you will want it to do .
For mounting i found it best to use a thick ply base as it won't distort as much as plain timber and it is pressed flat during manufacture then glue the tile to it with a silicon type sealer (Silastic or similar )as it will take up any differences in expansion rates of the two materials .
Also check to see if it is square because this can be an asset for marking out odd shaped objects particularily sheet metal parts as you can use use the edge of the tile to set a square against , just hold the piece down with some tape so it can't move then set up a datum piont and everything will be at right angles to it or parrallel with it .
IAN
Edited By IAN B on 11/05/2012 02:07:44
