Hi Anthony,
You don’t say what your workshop fabric is which may have some relevance on your problem eg the ability to retain heat to a reasonably stable level and not fluctuate to extremes causing the situation as admirably described by Andrew above.
For what it’s worth however I have a 14 x 14 ft wooden workshop (built 1984) for machining with an extension for a ‘cleaner area’ added later. It has a wooden floor that lays on paving labs to give an airflow beneath. The walls and ceiling – both pitched roof – are insulated with glass fibre bats between uprights and covered with oil bound hard board as is the floor. The windows were double glazed – I say were as when the extension was added (same length but 8ft wide with a walk through opening) one window was covered in to give wall space and the other lost by the opening. The extension has three windows covering 10 feet of the length again double glazed. This was insulated the same.
Initially the 14 x 14 side was heated using two 150 watt greenhouse heaters kept on all the time (no thermostat) throughout the day except the warmest months. On really cold days it would drop to 35-40 overnight sometimes lower and I would need to boost it with a fan heater – all quite expensive. After building the extension I bought two reasonably priced – under 30 quid – thermostatically controlled oil filled radiators. They can be set at 1, 2 or 3 KW. I have never, ever, had the need to use the 3KW and they are virtually always on the 1KW setting but they are on all the time. There is one in each part of the workshop and even throughout this winter the temperature has not gone below 59 overnight. I use it on a daily basis even on the coldest days.
To wit then regarding your question I can honestly say I have never had a rust problem on any of my machine parts – of course these always have an oil covering but nothing special applied as a rust preventative just the normal residue on oiling up. Perhaps a better indicator is the materials in store, some of which are quite oil free but they too show no signs of rusting. The only thing that does is some I” bar cut into various lengths to be used as packing for clamps on the mill. This is some 30 years old and has a very light trace not even enough to warrant removal.
Incidentally I don’t know if you have tried to remove the rust from your chuck and other parts yet but something that is very good for this is what are called ‘Garryflex’ abrasive blocks. If you are not aware of them, they come in four grades and are an absolute boon to finishing most materials particularly when used with parafin as a lubricant. They will also make derusting a surface rust a very easy job without leaving scratch marks like emery does. If you haven’t heard of them Google ‘Garryflex’ and you’ll soon find them but shop around the price varies quite a bit.
Finding rust on your prized posession is soul destroying – I remember leaving my newly made rotary table in the model tent overnight at a steam rally – I was mortified the next day to find it orange.
Hope this helps in some way
Regards – Ramon
Edited By Ramon Wilson on 27/12/2010 15:04:44
