Thanks for all the information; plenty for me to read. Don’t know why I didn’t think of looking on the Taylor Hobson website; after all they made my surface roughness gauge, doooh!
Right, now to try and answer a few points.
Ian: I’ve posted a picture of my Rubert set; did the one you see look like this? Rubert, and others, also made sets for specific operations. I have one with six squares on it aimed at shapers.
Sam: Sorry, I tend to forget that not everyone knows the esoteric abbreviations. In simple terms IGBTs look like a bipolar device at the output, but the input looks like a MOSFET, so it’s easier, but not simple, to drive. I won’t bore everyone with the details unless people are interested.
Chris: I did get one (well used) standard when I bought my roughness gauge, but some new ones would be good!
I’ve added a photo showing the bottom of the IGBT module. For reference it’s about the size of a paperback book. Each half bridge has the IGBT and diode dies mounted directly on an alumina substrate, which is what the gold rectangles are. Why you might ask are there ICs outlined on the bottom? We need to use a thermal paste specified by the manufacturer between the device and the heatsink. They recommend a thickness of 35µm and the use of screenprinting. Screenprinting, through a mesh, seems a little crude, so we had the idea of using a stainless steel paste mask, as used in the automated assembly of PCBs. The picture shows a test done at our assemblers using a gash paste mask, before we went to the expense of designing and having made a custom mask that covered only the alumina substrates.
In essence the IGBT-metal-coolant interface is a damn nuisance, but we have to have the metal in the way for other reasons. We just need to minimise the thermal resistance.
Right, back to the surface roughness measurement. The Ra measurement is essentially an arithmetic mean, easy to do with analogue electronics. The Rz measurement seems to be an average of the peak values only. This would be a bit tricker with analogue, but easy with digital measurement. The use of Rz would seem to be better intuitively, as it gives a measure of the total depth of the roughness, rather than just an average. So, in electrical terms it takes into account the crest factor of the surface. So, as far as I can see there is no simple way to relate Ra and Rz?
It would seem that we cannot really say whether the professional machine shop has or hasn’t meet the specification, unless they can measure Rz directly. However, we know that the heatsinks I made work at full power and high ambient temperature (100°C). Personally I think they ought to be able to match, or better, what the peasant writing this can achieve in his garage.
Should you be curious about the use of this heatsink look at
http://www.provector.co.uk and look under ‘News’ and ‘610 Series’. It will tell you a bit more about the unit, who the customer was, and where it might be used.
