Posted by Wesley Souza on 23/11/2022 16:12:45:
hi guys, I am very grateful for all the contributions, but from what I could see my idea is not usual. I only suggested such a procedure, because in my country the price of a surface plate is not very attractive. The currency is 5 times less than the value of the dollar and our friend the government still charges 60% for imports. Thank you for all your help and I will look for another method or alternative.
I'm not sure where you live, but how about this for a suggestion as a development of a conversation I had with a friend some time ago.
This friend, before his retirement was heavily involved in calibrating surface plates, the methodology, and the documentation, at quite a high level nationally.
His suggestion was that for most home workshops, and indeed some commercial ones, the most cost effective solution is a sheet of new good quality float glass, at least 6mm, and maybe a bit thicker if you can get it.
Ideally as fresh from the factory as possible, as an older new pane might have taken on a bit of a bend if it's been leaning against a wall for years.
The glass itself will flex, or distort according to how it's supported.
As mentioned by a poster above, a good way of supporting it horizontally, is to make a frame, and fill it with normal common plaster, as used on walls. The pane of glass is then floated on the plaster whilst it's still wet, so will be fully supported when the plaster cures.
The problem might be how to get a frame base, which won't bend with time, or warp if it's made of plywood.
You already have some fairly stable tiles, though they may not be flat enough to use as a proper surface plate.
Maybe use one, or more, of those as your base laminated together with plaster, frame it, fill the frame with plaster and float your glass on top.
That should prove both rigid and flat enough for most uses; I did try something similar, and it was fine for marking out and checking flatness etc, but it wasn't that good at retaining engineers blue for transferring onto other items.
The other consideration will be having a long flat strip of something along one edge to run a surface, or height gauge along.
On my normal workbench I have a 0.5m square of granite work surface, 40mm thick.
It's fine for rough and ready marking out, but it does have a dip of about 3 thou, so not good enough for blueing components.
Bill
