David
My advise is based on experience in the industry from 25 years ago, things may have moved on since then so keep this in mind.
The coolant used for grinding back then was different from the coolant used for general machining. Whereas your average lathe and mill would use soluble oil and water mix, we used to refer to it as "mistic", the grinding machines used a completely different coolant. Rather than the milky looking "mistic" this stuff was like water but with a slight colour – sometimes pink but mostly blue. I have no idea what the brand names were as the stuff was already pre-mixed by the time the grinder was topped up. Unlike certain mistics this stuff never went rancid so nasty niffs were not a problem.
Usage? Aim the coolant between the wheel and the job – flood it – but keep the wheel dressed and open to prevent burning of the job.
With just a few tenths of a thou to go – redress the wheel with a couple of slow passes with coolant running on the diamond. At this point, turn off the coolant flow and check the condition of the wheel surface by very lightly running a finger tip from side to side on the running wheel. The wheel should feel totally smooth. If gritty bits are felt then run the diamond across a couple times more until it DOES feel smooth.
Please note – this is how I used to do it for getting mirror finishes on hardened tooling. Sure, it might not apply to what YOU want to do but if I can offer the best advise I am able you can pick the bits out you want and chuck the rest away.
Whatever you do though, I cannot accept responsibility for lost digits/appendages.
Happy grinding
Rik
Edited By Rik Shaw on 06/12/2013 18:08:16
Edited By Rik Shaw on 06/12/2013 18:14:30
