Supplier metal formings
Home Forums Website Questions, Comments, and Suggestions Supplier metal formings
  • #238943
    RonMc
      @ronmc
      I require 6 aluminium endplates, 4mm thick:
      Dimensions are:
      200mm inside dimension
      75 mm legs
      Height 100mm
      any ideas where I can have them made I haven't the facilities to bend anything like this.
      Ron Mc
      RonMc
        @ronmc
        Aluminium channel shaped plates
        #238953
        Tim Stevens
          @timstevens64731
          It would help to know – endplates for what? Clearly there are bends, but how long?
          etc
          Tim
          #238958
          RonMc
            @ronmc
            Thanks for the query Tim
            The height is 100mm, width is 200mm inside dimension and the side legs are 75mm long.
            they are endplates for pedal steel guitars.
            #238961
            michael darby
              @michaeldarby61557
              Try your local fabricators or sheet metal shop,they will have the necessary equipment
              #238962
              RonMc
                @ronmc
                Yes Michael, I haven't tried any local searching yet, the guy who did them for me previously can't do them anymore so I just thought, maybe some of you chaps would know someone who did small orders.
                Thanks for the replies though.
                #238964
                duncan webster 1
                  @duncanwebster1
                  I can think of at least 2 in Warrington, depends where you are.
                  #238965
                  RonMc
                    @ronmc
                    Milton Keynes Duncan.
                    #238966
                    martin perman 1
                      @martinperman1
                      Ron Mc,
                      There is a Fabrication Company in St Neots who do all of the Fabrication that the company I work for need, they work in Stainless mostly but it would be worth asking, the company is IMPlastec and one of their directors is called Ian. I dont have the office no but if of use I can PM it to you tomorrow.
                      Martin P
                      #238968
                      Tony Pratt 1
                        @tonypratt1
                        Posted by RonMc on 16/05/2016 19:26:52:
                        Crown Precision Engineering Ltd
                        Steel Fabricator
                        Address: Stadium Business Court, Denbigh West Industrial Estate, Denbigh Rd, Bletchley, Milton Keynes MK1 1AX
                        Phone:01908 376080
                        Tony
                        #239015
                        RonMc
                          @ronmc
                          Thanks for all your replies, I am making some enquiries, I'll post how I get on.
                          Best Regards Ron Mc
