Hi Ian
I may off the track here but I seem to remember from reading a book from Babcock and Wilocox about twenty five years ago that there are several problems.
Cast Iron has excellent compressive strength (Victorian England would have fallen down without it) but very low elasticity (I think that is the correct term in the circumstances), a property which is diminished as the temperature goes up. In other words the material gets weaker as the presure and temperature goes up.
In the same book or maybe another, it mentioned the use of superheated steam in Naval vessels and quoted someting like 700 degrees F for 2,300 PSI.
Structurally cast iron is like cement rather than wood in that cement is lots of particles with inclusions – sand whereas wood has a grain.
Steel is more homogeneous than cast iron and better able to withstand bursting.
I’m not sure much of this makes sense but I hope it gives a direction for further research.
