Well after much ado about nothing here I am again with another update, finally! having plucked up the courage to give this anodizing lark a go I found it wasn't actually so hard after all.Not sure why I was so chicken about doing it, just nervous of the unknown probably, oh and the risk of ruining irreplacable parts maybee. Right so now that i have faced my fears the photos below show the progress to date. here's the results of the first test run.
not too bad an effort me thinks……… so onwards we go….. here's the anodizing bath in action doing the first run of the v12 fin blocks and heads.
I had originally set up to do all the parts at the same time but found that the load was way too high for the power supply to cope with requiring more than 15 amps to run and as the power supply is only rated to 15 amps max it just wasn't going to work. The solution was to just downsize the parts stack to both fin blocks and heads as the parts are mated together and had to be the same colour. even then I had to drop the voltage to 10 volts and keep watch on it as the overload would trip out every 10/ 15 mins or so and needed to be reset. this was less than ideal in theory but seems to have worked out ok in practice as the parts came out perfectly barring a small blemish where the colour didn't take up, I suspect because the cleaning stage wasn't good enough. Oh well. photo below shows the first parts run fresh out of the bath.
A very nice even colour and finish so on with the next bits, drive belt housing and cover.
These parts didn't quite go as planned and were a very dissapointing result. It looks like they anodized ok but they didn't appear to take up any colour. These were the only failure of the day and were also the only parts that were sandblasted in finish so I'm not sure if that was the cause or weather it is something else, anyone got any bright intelligent ideas? below is a photo showing all the parts that were done including the test parts, not a bad days effort I reckon but there's still a few questions that need answers.
Cheers for now
Dean
Edited By dean clarke 2 on 25/09/2016 19:19:58
