supercharged V12 2 stroke
Home Forums I/C Engines supercharged V12 2 stroke
Viewing 25 posts - 176 through 200 (of 273 total)
  • #219938
    Old School
      @oldschool
      Dean a very impressive engine and sound awesome followed the whole thread very interesting. I did my apprenticeship in the merchant navy the ship were powered by straight 4 or 6 cylinder 2 stroke diesels turbo charged so I new it work. Looking forward to your next project.
      Hope to be in NZ on holiday next year would love to see it.
      John Stevenson 1
        @johnstevenson1
        Well just an awesome thread.
        Must admit that I hadn't been following it at all and last night saw it was into 8 pages then so sat down and had a read.
        Totally blown away both by the quality of workmanship and the speed of the build given how many parts need making and the complexity.
        What really made it for me though was the single minded dogged approach to the whole project.
        I must admit I was starting to feel sorry for Dean after a couple of pages of nearly everyone saying it wouldn't work and the description was wrong. Many adding their experiences of having leaned against one when a lad which obviously makes them an ex-spurt.
        But no our intrepid hero, Dean puts all this aside together with his bent crank, and quadruple bypass herniated appendix and just gets on with it to prove to all the doubters that he can do it and it works.
        Just the right amount of pictures and information to keep everybody interested without them falling off their chairs.
        Unlike a recent post where we had 20,000 pictures of a main bearing cap and then the poster fell out his pram. He'd do well to read a post such as this.
        Well done Dean and I would not be surprised to see your name in the Joe Martin Museum of Craftsmen in the future.
        #220444
        Howard Lewis
          @howardlewis46836
          Can only be in awe of Dean's design and machining skills, his persistence and to marvel at the end result.
          Words are scarcely adequate to describe my admiration. SUPERB!
          And it look as if there is a lot more to follow! I shall watch this space, (or whatever is set aside for the successors)
          #221396
          dean clarke 2
            @deanclarke2
            Ok so I have been quietly working away on solving the starter motor problem and I reckon I have found a suitable solution. I surfed my way through trademe and found an old bendix type starter off a ford transit van for $45, just the ticket me thinks. If that doesn't have the grunt to turn it over fast enough then there's something really wrong and I quit!!! Below is a photo of the starter after I removed the bendix gear system. The plan is to shorten the shaft and add an adapter to suit the dog clutch I have made for the V12 but to also make an adapter to suit the rubber cone style of clutch for other projects and for using once the bigger engines have been run in properly and no longer need the dog clutch system. I will dismantle the starter to check all is well inside and give it a good clean and a coat of paint, then make some mounts and handles blaa blaa blaa and hey presto a nice newish starter………. well thats the plan anyway, spose I'll have to wait n see weather or not it becomes a reality LOL.
            Cheers for now
            Dean
            #221399
            Ian Abbott
              @ianabbott31222
              How fast does it need to turn to get the blower up to speed? Starter motors tend to be high torque, low RPM. You might need to gear it up somewhat.
              Remember the old Hucks Starter? Perhaps you could build a scale Model T and fit it with a drive shaft……..
              Ian
              #221408
              Bill Pudney
                @billpudney37759
                Brilliant Dean, absolutely brilliant.
                Congratulations.
                All the best
                Bill
                #222177
                dean clarke 2
                  @deanclarke2
                  Ha ha I just googled the hucks starter and now know what you were on about, that's actually not a bad idea LOL. thanks for all the kind words you guys it really helps to overcome the frustration of stuff not working out as per the plan. I am currently busy trying to get the new starter under way and will update the thread when I have something to show for all my efforts. As for the starter speed query, the problem with the starter i was using is that the internal friction (new engine) and the fact that this engine has 12 compressions happening every crankshaft revolution means there's a lot of load on the starter and it simply didn't have the running torque to handle it for any length of time, so consequently it ended up hand grenading itself into oblivion……..hence the requirement of a new starter motor. I am also currently redoing the carbs and intake manifold to increase the airflow into the blower.
                  cheers for now
                  Dean
                  #222217
                  Ian S C
                    @iansc
                    One of my nephews uses a motor bike starter motor (don't know it's origin, but he had an 1100 cc Kawasaki), it's about 150 mm L by 50 / 60 mm dia, he uses it for starting a 15 cc GP engine on a RC Hydroplane, it just needed a small pulley to fit over the helical gear milled on the shaft.
                    Ian S C
                    #222316
                      Congratulatiojs Dean, that's a brilliant achievement – finally lived up to the title of the thread!
                      Perhaps you will shame me into getting my single cylinder engine working
                      dean clarke 2
                        @deanclarke2
                        Hope you share it with us all Neil, love to see it mate.
                        cheers
                        Dean
                        #222770
                        Muzzer
                          @muzzer
                          Incredible workmanship and dedication. I don't have the attention to detail or fine skills to do anything like this. I've often said I'm closer to an agricultural engineer than a workshop.
                          Pity there was so much bickering about whether this is technically scavenge pumped or supercharged early on. Either way, there's certainly no doubt it works!
                          It seems to have run out of carburettor or is possibly strangled by the supercharger flow rate (pulley ratio?), so hopefully you can optimise whatever it is. You may need to bolt the bench down!
                          Murray
                          #222794
                          Alan Jackson
                            @alanjackson47790
                            Absolutely brilliant Dean, an inspiration.
                            Thank you
                            Alan
                            #224854
                            dean clarke 2
                              @deanclarke2
                              Well it has been a little while since an update, but I have not been completely idle.I have been working away on turning the starter acquired on trademe into a usable model engine starter, photos below show the progress to date
                              That's all for now
                              Dean
                              #224866
                              john fletcher 1
                                @johnfletcher1
                                When I was working as an auto electrician on heavy goods vehicles (all diesel) back in the 1950's, I made a trolley Acc as it was known by the fitters. Any one member Leyland, AEC, Perkins and Gardner , not a foreign make in sight those days. Actually the trolley Acc was 5 large 6 volt batteries connected in series ,all fastened to a 4 wheel trolley, with a pair of very large jump leads, one directly connected to the common Neg with a very large croc clip on the free end. The Pos lead had croc clips on both ends. After an engine rebuild, the engines were very stiff, so a 12 volt starter got 18 volts and 24 volt 30. All the auxiliaries were disconnected and I never had a burnt out starter motor. The same arrangement was used to start some old lorry engines after a frosty night. So you might consider doing the same if your starter is short of grunt, give the starter a few extra volts. I fitted a 12 volt dynamo as a DC motor, using 18 volt on a small hoist, lifting things out of the degreasing tank. Best of luck with your fantastic project. John
                                #224943
                                dean clarke 2
                                  @deanclarke2
                                  Hey thanks for the info John, I reckon this starter will be more than adequate for my engines. Have also started to carry out the mods to the engine itself, starting with the intake for the blower.photo below shows the initial layout change.
                                  will update with photos as things get completed.
                                  cheers for now
                                  Dean
                                  #226827
                                  dean clarke 2
                                    @deanclarke2
                                    So we are well under way now with the mods and the engine has been completely stripped down. The first thing on the list of must do's is the enlargement of the intake ports and the supercharger exhaust ports which has now been done. Photos below show the progress to date.intake ports modified 1.jpg
                                    The intake ports have been increased by 50% of the original diameter with the exhaust by 25% and also being trued up with the manifold and block holes to make good gas flow. ( bit of a noob mistake that but never mind all fixed now).
                                    Next is to do the toothed belt drive, backplate and cover and to dial in the transfer timing to make sure it is what it's supposed to be and maybee advance it by a few degrees. I will keep you all updated as soon as I have things done. Also I am building my anodising plant so I can add some colour to this engine.
                                    cheers for now
                                    Dean
                                    #235044
                                    dean clarke 2
                                      @deanclarke2
                                      Just a quick heads up, I have finished modifying the two toothed belt gears I got from belting online to fit on the V12 and am now in the process of making the drive belt housing and cover, these will both be anodized with the two heads, fin blocks, prop driver and spinner nut. I will upload photos later on tonight time permitting.
                                      cheers
                                      for now
                                      Dean
                                      #235049
                                      Martin W
                                        @martinw
                                        Looking forward to you next instalment Dean.
                                        #235063
                                        V8Eng
                                          @v8eng
                                          Posted by Martin W on 18/04/2016 00:31:23:
                                          +1 for that, great stuff!
                                          #235213
                                          dean clarke 2
                                            @deanclarke2
                                            Ok so here are some photos of the progress to date with the mods etc being carried out on the v12
                                            dismantling after the first few runs to check engine condition and carry out modifications to improve performance, looks etc.
                                            having removed the crankshaft it was discovered that the lubrication of the main bearings was somewhat less than ideal so a bunch of corrective mods were carried out on the bearing shells to allow a greater influx of lubricant to the main journals. The next engine will allow for pressure fed lube straight from the blower to ensure good lube at the mains.
                                            The photo below shows the crank and bearings etc all refitted to the block and the supercharger refitted after the described mods were carried out.
                                            here are the photos showing the progress on the toothed belt drive being fitted at the moment. the drive speed has been increased to 3.47 to 1………
                                            machining the bottom gear to fit the standard carrier I made previously.
                                            All fitted up the the carrier……….
                                            Now I only need to finish machining the belt cover housing and cover plate……. and by that I actually mean start maching it LOL….
                                            untill next time.
                                            Cheers
                                            Dean
                                            #235846
                                            dean clarke 2
                                              @deanclarke2
                                              Well here's the latest development for the belt drive cover………
                                              Milling out the inside of the backplate………
                                              End of the roughing out stage 1, cover plate next then bolt them together to finish off the profiling.
                                              Cheers for now
                                              Dean
                                              #236402
                                              dean clarke 2
                                                @deanclarke2
                                                So I have managed to make a bit more progress on the toothed belt drive for the v12, photos below show progress to date……………….
                                                cover plate.
                                                cover plate roughed out ready to finish to the back plate outline……
                                                all finished and bead blasted….
                                                Rear view of case.
                                                Idler slash tensioner pully…….
                                                Test fitted to make sure it's all going to turn afterwards lol……….
                                                Better put the cover on to make sure its all still going to turn
                                                Cheers for now……..
                                                Dean
                                                #240432
                                                dean clarke 2
                                                  @deanclarke2
                                                  So it's been a little while since I last updated this thread so i though it was about time I pulled finger and got something done, here's the latest goings on with the anodising setup.
                                                  Now where did I put the acid?
                                                  Cheers for now
                                                  Dean
                                                  #240466
                                                  John Olsen
                                                    @johnolsen79199
                                                    Maybe you would have more time for the engine if you did not waste so much time fixing old cars!
                                                    Acid is a bit hard to get these days in NZ, I believe someone threw some at someone once. It doesn't matter for pickling boilers since there are readily available alternatives that are better, but of course for anodizing you need the real thing.
                                                    dean clarke 2
                                                      @deanclarke2
                                                      LOL, Yea but if I didn't fix the cars I'd have no money for anything so its a catch 22 really, Oh well, anyone know a rich donner????? no? bugger I'll have to keep at it then……. Hopefully I'll have the starter back together soon as well. Oh, and i found my acid, got a 20 ltr container of brand new batt acid a few years ago just for a job like this.
                                                      Not to long before some colour arrives on the parts i hope
                                                      Cheers
                                                      Dean
                                                    Home Forums I/C Engines Topics
