Super 7 Gearbox Query
Home Forums Beginners questions Super 7 Gearbox Query
  • #511507
    John Button 1
      @johnbutton1
      What oil should be used & where is the oil level plug/screw for the Myford Super 7 Quick Change Gearbox please?
      John Button 1
        @johnbutton1
        #511508
        Thor 🇳🇴
          @thor
          Hi John,
          There is a write up of lubricating Myford lathes here. You can find the gearbox manual here. It has been discussed on the forum earlier.
          Thor
          Edited By Thor on 04/12/2020 04:37:21
          #511625
          ega
            @ega
            Posted by John Button 1 on 04/12/2020 02:56:22:
            … where is the oil level plug/screw for the Myford Super 7 Quick Change Gearbox please?
            The drain and fill/level plugs are readily visible on mine: drain is brass hexhead underneath and the fill is the slot-head on the RH side.
            The plug on the left front is for installation and should not need to be disturbed.
            #511626
            ega
              @ega
              Duplicate post caused by pressing back button after posting and assuming post had not registered- not sure how normal this feature is?
              Edited By ega on 04/12/2020 15:02:28
              #511637
              Grindstone Cowboy
                @grindstonecowboy
                As I keep telling others in my family, avoid pressing the Back button on any browser, more often than not it causes issues you could do without.
                yes
                Rob
                #511670
                ega
                  @ega
                  Posted by Grindstone Cowboy on 04/12/2020 15:48:24:
                  yes
                  Rob
                  Yes, this irritation also has the effect on other sites of logging you out when you have just logged in so I suppose is not to be laid at the door of MTM.
