Supaburner’s for Model & Toy Steam Boilers Explained
Home Forums Hints And Tips for model engineers Supaburner’s for Model & Toy Steam Boilers Explained
Viewing 23 posts - 1 through 23 (of 23 total)
  • #418457
    Blue Heeler
      @blueheeler
      Supaburner's for Model & Toy Steam Boilers Explained and how to make one.
      Edited By Blue Heeler on 12/07/2019 08:43:01
      Blue Heeler
        @blueheeler
        #418468
        Eric Cox
          @ericcox50497
          Brilliant burner. Can you explaim the fiberglass wick a bit more, ie how do you make or where do you obtain the wick.
          #418474
          Baz
            @baz89810
            +1 for further details of fibreglass wick
            #418475
            Chris Bradbury
              @chrisbradbury76252
              Now you have explained how it works I'm going to make one. Thanks for sharing.
              Chris
              #418488
              Ian S C
                @iansc
                Fibreglass wick as for lamp for aromatic oils, or threads pulled from woven fibreglass cloth, think I'v got some of that, it was called Dynal cloth 50 years or so ago, we used it for abrasion resistance on the leading edge of the tailplane of our Cessna topdressing aircraft. I have mad similar burners, but both ends of the burner tube went into the fuel tank, and the burner end consisted of a complete loop with the little hole in the bottom of the loop. I used asbestos string.
                Ian S C
                #418491
                Ian S C
                  @iansc
                  Fibreglass wick as for lamp for aromatic oils, or threads pulled from woven fibreglass cloth, think I'v got some of that, it was called Dynel cloth 50 years or so ago, we used it for abrasion resistance on the leading edge of the tailplane of our Cessna topdressing aircraft. I have mad similar burners, but both ends of the burner tube went into the fuel tank, and the burner end consisted of a complete loop with the little hole in the bottom of the loop. I used asbestos string.
                  On second thoughts don't use Dynel, it,s not fibreglass, but acrilic, I forgot that.
                  Ian S C
                  #418492
                  Circlip
                    @circlip
                    Aren't glass fibre raw materials IE woven cloths and roving's pre coated?
                    Regards Ian.
                    #418585
                    Blue Heeler
                      @blueheeler
                      Fibreglass wick should be pretty easy to come by from large hardware stores, eBay, BBQ & fireplace sellers etc.
                      Ian, a closed loop supaburner sounds interesting. I will have to make one and try it out.
                      #418589
                      Simon Collier
                        @simoncollier74340
                        Looks impressive. Did you actually crimp the end trapping the wick fibres? Not ideal for silver brazing I would have thought. Also, is the lid an air tight fit, or just lacking a breather hole? Third question: how many burners to replace the 4 wick x 1/4" diameter burner I made for my Ellie tram? The wicks are ceramic by the way, a step up from fibreglass. 4). Any reason not to have 2 or more burners supplied by the same tank?
                        Your workshop is indecently tidy and orderly. I am jealous, as mine is like a commando training obstacle course.
                        #418594
                        Blue Heeler
                          @blueheeler
                          G'day Simon,
                          !. You can just poke the loose fibres in before silver brazing.
                          2. I have fibre washers on some and O rings on other screw caps so pretty air tight.
                          3. Not sure about that.
                          4. I've seen 2 and 3 wick Supaburners with the copper tubes at staggered lengths. They give off a lot of heat. Just need the spirits container big enough to feed them for a period of time. Best thing about these burners is that the materials are pretty cheap and makes multiple experimentation possible. I want to give one of Ian's closed loop ones a try.
                          #418604
                          martin perman 1
                            @martinperman1
                            Posted by Ian S C on 12/07/2019 12:54:46:
                            Ian S C
                            Ian,
                            I collect campingstoves and have a stove that runs on petrol it is a closed loop as you describe, the burner hole is at the bottom of the rim and when lit is very efficient, the filler cap doesnt have a open whole in the cap, there is one but is has solder over it so that if the stove over heats it melts the solder to dump the pressure, the stove was made in the 40's – 50's possibly earlier.
                            Martin P
                            #418613
                            AdrianR
                              @adrianr18614
                              What a wonderful idea for a burner.
                              I wonder if stove glass fibre rope could be used as a wick.
                              #418621
                              Simon Collier
                                @simoncollier74340
                                Thanks for answers. One more, what diameter is the burner tube? Sorry if you said it in the video.
                                #418736
                                Blue Heeler
                                  @blueheeler
                                  Posted by Simon Collier on 13/07/2019 10:36:55:
                                  G'day Simon,
                                  The smaller one the copper tube is 1/4 and 5/16 for the larger one.
                                  #418737
                                  Blue Heeler
                                    @blueheeler
                                    Posted by AdrianR on 13/07/2019 10:07:15:
                                    Yes that's fine, just unweave some strands.
                                    #418741
                                    michael howarth 1
                                      @michaelhowarth1
                                      Fascinating stuff Blue Heeler. How do you control heat output?
                                      Mick
                                      #418744
                                      Boiler Bri
                                        @boilerbri
                                        Thats a great idea. However I would not change my wick burner in my Roundhouse loco though. I know that the burner runs out of meths before the water level becomes unsafe in the boiler.
                                        If anybody has a go at fitting one to an old Mamod i would also advise caution as i think some of there brass boilers are soft soldered and the above would apply even more.
                                        Ever cautious 🤔💥
                                        Bri
                                        #418805
                                        Ian S C
                                          @iansc
                                          Don't know what Blue Heeler used(probably similar). I use 1/4 OD copper mainly, but as I don't buy much, its a case of whats in the junk box. I did have some copper plated steel tube from a fridg, that worked ok, it was either 6 mm or 1/4".
                                          Ian S C
                                          #418932
                                          Blue Heeler
                                            @blueheeler
                                            Ian, do you happen to have a photo of your closed loop burner?
                                            Cheers,
                                            Jim
                                            #418995
                                            Ian S C
                                              @iansc
                                              Sorry Jim, can't even remember where I put it. The first one I built, the tank was vertical copper tube about 2 1/2" high x 1" dia, the loop tube 3/16" copper tube went into the tank near the bottom, and was bent up so the the hot end was above the top of the tank, it worked but was not a good design as the flame area was too high to be of any use. I did make a few more, but as I use gas for heating most of my hot air motors I didn't do too much development work, perhaps I'll have another go.
                                              Got a tin boat about 26" long powered by a hot air motor with a single wick meths burner, perhaps a pressure burner would give it a bit of a boost, must try that.
                                              Ian S C
                                              #419059
                                              An Other
                                                @another21905
                                                Saw this thread rather late on (Internet connection in our village was down for three days over the weekend), and thought this info may be useful to someone-.
                                                I needed some fibreglass rope for a particular job, and by chance found out that I could easily get different sizes of F/G rope intended for the seal around the edges of woodburning stove doors. It used to be asbestos, but since that has disappeared it has been replace by F/G. I was able to buy it by the metre(?) very cheaply in various diameters, and it seems to be OK for wicks.
                                                #419116
                                                Blue Heeler
                                                  @blueheeler
                                                  Posted by Ian S C on 15/07/2019 12:48:13:
                                                  Ian S C
                                                  Thanks for looking Ian, I will try and make one when I get some time.
                                                  Kind regards,
                                                  Jim
