Chemical process maybe? Certain sensitive substances are made by evaporating solvents in a vacuum. The vacuum considerably reduces the temperature needed. If the vacuum failed, the temperature might rise, causing an uncontrolled thermal runaway as the substance decomposed. Bang!
Or a vacuum brake: don’t drive off until the vacuum is strong enough to release the brake. Dangerous to the machine, not humans.
Odd!
