Posted by Fowlers Fury on 17/01/2023 15:18:40:
True enough about chrome re-plating these days. For one of my rebuilds where surface rust had ruined the original chrome plating, I used a nickel plating kit. The process is safe enough altho' tedious & requiring a LOT of preparation. A preliminary coating of electroplated copper is advisable on mild steel. The final finish of course will not look as reflective as chromium but a polish with Solvol or the like and the appearance is very close. For chrome-plated Cu oil pipes that needed replacing, I made new pipes then silver coated them. Again, a simple, safe process used extensively by clock restorers.The silver (from silver nitrate soln) binds directly to the Cu surface and is resilient to oxidation if coated with a non-yellowing clear varnish..
A low-res image of the Panther but the covers on the rear shocks, the front brake actuating arm, tank filler cap and a few other smaller items had been Ni plated back in '84.
I thought all Panthers had to be fitted with sidecars, the bigger the better, they all were in my young day. They fired every other lamp post was the rumour. This one looks very nice indeed.
Edited By duncan webster on 18/01/2023 20:08:15
