Tried anything and everything what could get my mittens on, still got the Quink and fabric dyes no substitute for the real thing which went off 11 years ago sold by a place over Leicester.
Must have been lucky just drove up to a local chemical suppliers asked what needed then went back following week after they got to know me, no names and walked out with 25ltrs Sulphuric, 50ltrs distilled water, 10 ltrs hydrochloric acid £30.
Very true sulphuric at 17% will rot thin steels away within two weeks, don't ask had a leak from a 4ft tank but still got the little 12".
Back 15/16 yrs not much info available only three sources in the world and what was told was porkies or something blatant omitted.
Used to run anodising at 21% initially then dropped to 19% then 17% both at 13.6V. Even done hard anodising. Just a slight tingle retrieving parts that's dropped off at 21%, rinse off with water.
Sooner pay for it to be done since eventually found an anodisers that cares, can match up with existing even different aluminiums and finishes sent in. Usually send in two colours a month last 10yrs after 6 years diy then prior 6 yrs pro again. Only reason started diy anodising was of poor service, lost hand made one off parts, not ready when said would be, scrap parts quite often certainly the ones in Brum borderline scrapped three jobs £11k.
Just law to themselves anodisers, caused me serious grief over the years, excluding above when it don't come out right precision parts stripped once, twice, three times? who knows so when put threaded parts together nothing lines up. One job last year at a Brummy place 1mm pitch thread ended up 290 degrees further round than acceptable = scrap £400, nearly all like that from experience. If job done right first time with no or little cleaning anodising adds to any surface, more so hard anodise and forget the depth and surface build up off hand.
One of the pros use does stuff for a prestige major car producers, they do use titanium for jigging the parts usually spring clips of some sort o individual racks dunked in to the sulphuric black with use.
Never ever had any success using aluminium wire, fine at first then just lose electrical contact often within 3 mins. Used to use 6082 filed up tapers and wedge in a part or titanium wedge in to a hole.
