Windy The problem is that involutes gears actually slide across each other. At your speeds gears with the life of say 2 million rotations (which at normal speeds would last years) at your speeds (80,000 rpm) would last for about 25 minutes. That is if you can get such gears.
There may be other ways of building your reduction gear. The first was invented by an American clock maker Aaron Dodd Crane. It is the daisy wheel gearless clock drive. You will find an example here.
The other method is the ‘Harmonic Drive’ you will find a good example here at http://www.hds.co.jp/HDS_hp_english/english/principle/index.html . This one is less mind blowing than Aaron Dodd Crane’s design which I made for a clock I gave to my daughter.
If I had known of C.M. Musser’s idea about Harmonic drive when I was into turbines I would have tried it. I have not yet figured out how to make the ellipses without a CNC machine but I think it could be done. With a CNC lathe it would be a doddle. They claim that there is no wear on the teeth.
Jens Eirik Skogstad writes about using piano wire in sintered bronze bearings. I did the same they lasted about ½ hour then I tried sintered carbon (battery electrodes) but these were no better. But bearing in mind my reasons for my turbines were different from yours. I was always trying to push the envelope over the limit
