I was trawling through my previous posts and looked at this one. There is another cause of problems. These are the bearings.
The dreaded “mmm grrrGRR WheEEE POOF” which happens when the gears fail is one problem. A break such as you suggest may be of little use. When the load comes off, a turbine wheel it will spin up very quickly (very very quickly). Think of the energy the disk contains and the heat dissipated by the break and the forces involved
There is another dreaded noise which is the “mmmm gRUK (and sometimes the ‘Clunk’
”. The ‘gRUK’ or the less damaging ‘sKREEeeek’ is when bearing welds up. A light wheel running at say 80,000 rpm has a huge energy. Think of the forces required to stop that little number within say ½ to 4 rotations. I have had bearings where the lubrication has literally been vaporised and heated to read heat, the bearings (mainly of ‘delta metal’
melt. I have had ball bearings becoming welded together. The best failure of the lot happened when an alloy casing caught fire. This one caused huge consternation amongst the people who gave me the casing – it was an old aircraft instrument. Ok it was originally powered by air an cold air at that. I was using flash steam ay about 250°C. The original wheel ran at about 60,000 rpm, I was running at 170,000 according to my oscilloscope.
When testing, I always started with an air puff test then worked up slowly with longer and longer runs. Eventually I would start running on flash steam. My testing was for different reasons to yours. I was investigating power losses. Yours are to produce a small high powered engine for racing. A race lasts for how long? Four to five minutes? With four five races in an afternoon? Your turbines would be serviced after each meeting with perhaps not more than nine meetings a year. Mine were often pushed beyond their limit.
Using bits from air tools might be O.K. but remember air tools are used in short bursts of a few seconds. I do not think I have heard ‘Windy Billy’ (even a Die Grinder) running for more than a minute or two at a time. So your turbines will have run for much longer and to be much more rugged and efficient.
Small turbines can be fun and one can become addicted to them.
Rgds
Dick
Drat the ‘smileis’
Edited By Richard Parsons on 08/09/2011 11:11:13
