Suffolk dredging tractor boiler.
Home Forums Miscellaneous models Suffolk dredging tractor boiler.
  • #123442
    Mark P.
      @markp
      Hi all,does anyone know anything about the boilers used on the Sufolk dredging tractor? I know that they are center fired and have a central vertical chimney but can't for the life of me work out how they work and how they tubed. I assume that they are tubed. Also what other boilers would be suitable for this application.I am considering scratch building something similar.
      Regards Mark P.
      Mark P.
        @markp
        #123446
        michael howarth 1
          @michaelhowarth1
          John, this tractor was featured in ME vol 146 with plans and constructional details by John Haining. It is described in 3" scale I believe. I have vol 146 as a bound volume and as I also live in Lincolnshire it may suit you to borrow it to copy them. If so give me a ring, I have left a PM
          Mick
          #123448
            It hardly has any tubes, just three that run across the top of the firebox of the water tube variety.
            Haining's The "Countrymans Steam" Manual has sufficient drawings in it to make the boiler.
            You could also use a vertical boiler rather than the horizontal of the Sufolk, there are a couple in teh MHS list and Harris's book is also worth looking at.
            J
            Edited By JasonB on 29/06/2013 20:04:28
            #124059
            Allan Wilson 4
              @allanwilson4
              Hi All
              I noticed your postings of 2 months ago on the Suffolk Dredging Tractor boiler. Do you have any John Haining (or other) drawings / description for the copper version of the boiler (rather than steel), or knowledge of a source for the copper version drawings / description..
              Thanks
              Allan
              July 7th 2013
              #124061
              Boiler Bri
                @boilerbri
                I made a Suffolk with the original boiler as described in the articles in me.
                It was a good steamer and was easy to fire. cadserengco@gmail.com
                As far as i know there is no copper version for this model.
                The steel one is fine.
                Have a look at Station road steam archive, there area  couple there with different styles of end plate fixing.
                Bri
                Edited By Boiler Bri on 07/07/2013 22:38:05
              Home Forums Miscellaneous models Topics
