Suds pump
Suds pump
Home Forums Beginners questions Suds pump
Viewing 2 posts - 26 through 27 (of 27 total)
  • #661137
    MadMike
      @madmike
      I use a tank with a weir which isolates any swarf that gets washed down with the coolant. For a pump I simply use a small submersible pond/fountain pump. Very low cost and very reliable. Look for one that will lift your coolant around 4 or 5 feet if the tank is on the floor. I have mine below the tray on the lathe stand and a 4 feet lift is more than enough.
      Danni Burns
        @danniburns84841
        I found this on ebay. Can anyone advise me if it would be a good choice for lathe coolant?
        Its £19.50 and Says:
        Specifications
        Voltage: 12v
        Power: 100W
        Flow: 1-4L/min
        No-loading Current: 2.5A
        Loading Current: 5A
        Work cycle: 30min
        Theory: Gear pump
        Pump Diameter: Approx. 16×6.2cm
        Inlet tube (approx.): 0.8x100cm (D x L)
        Outlet tube (approx.): 1x100cm (D x L)
        The actual ebay title is below (if anyone wants to find it themself:
        12V Electric Car Oil Extractor Pump For Transfer Fluid Engine Vacuum w/Hose 100W
