‘Good old’ fractional horsepower motors made by BTH, Met-Vick, AEI, GEC etc in the 1940s to 60s had plain bearings lubricated by wool yarn in contact with the shaft and sitting in an oil reservoir. I dismantled a British motor probably made in the 1970s where the wool was replaced by a white, wet paste which was oleoscopic. I would say it had the appearance of finely ground PTFE. The paste was packed into the cavity and entered the bearing through an oil hole and filled a generous groove that put it in contact with the shaft. As well as lubricating the shaft, the paste picked up debris and was quite black where it was in contact. I was surprised too at how poor the manufactured finish seemed to be on the shaft but it worked OK. Does anyone know what the white paste might be and where it can be obtained? It would be useful stuff to have in the workshop.
Andrew M
Edited By Andrew Moyes 1 on 24/04/2016 09:10:46
