Stuck Tich piston
Stuck Tich piston
Home Forums Beginners questions Stuck Tich piston
Viewing 13 posts - 26 through 38 (of 38 total)
  • #762757
    duncan webster 1
      @duncanwebster1
      I think getting a gunmetal cylinder red hot is asking for tears
      Bazyle
        @bazyle
        Have you tried tapping it, ie small blows not making a thread. About 50 years ago in ME there was a regular section called Jeynes Corner and I think it was in there that he recounted how the millwrights in his place of work (probably in the ’20’s) when big nuts were stuck in ‘t mill they would assign an apprentice to tap it with a hammer all day and this would eventually release it. I have often found this to be sound advice if not in a hurry.
        #762786
        Mark Salzedo 1
          @marksalzedo1
          Much obliged for all the feedback. As I am in no hurry, I will experiment by positively (but not too forcibly) striking a wooden dowel about 15mm diameter with a rubber or wooden mallet to free the piston. I’m not confident that it will work but I’d rather try the least destructive options first and if unsuccessful work my way toward more damaging scenarios. On a positive note, the other piston moves without impediment and the chassis rolls freely!
          #762812
          noel shelley
            @noelshelley55608
            Hey Mark, we are assuming that the cause of the problem is the O ring, not metal seizure and have no idea as to the equipment you have at your disposal or your knowledge of models or engineering. The dowel will take the shock, though that is what you need so the use of wood or rubber mallet will not help, a normal hammer is fine. Place the cylinder on a solid heavy object,try to protect the machined face with thin wood or Etc the idea being to apply the load to the piston whilst supporting the cylinder.
            Small press = G clamp ! Say 4 – 6″ Cut your dowel only 1/4 or1/2″ to protrude from the cylinder, keep the cut square at both ends. Remove the cylinder end cover studs if used. Place a piece of thin wood or stiff card on the fixed end  of the clamp, may be hold the clamp in a vice. Now hold the cylinder and dowel end with dowel to the screw and tighten ! This arrangement if it will still not see things your way can now be heated. Talk of “dull red” is unnecessary and way to hot ! The O ring will give up long before that temperature is reached. Some one mentioned avoiding the fumes as the O ring burns out – a good plan, best do it outside ! Good luck. Noel.
            #762817
            noel shelley
              @noelshelley55608
              Bazyles mention of the apprentice boy and a hammer, it works but the modern apprentice, if you can find one, not on his/her phone gets the air hammer out and in minutes has the nut off and deafens all around, that’s why the oxy propane is preferred, a skilled hand can blow the side off the nut without harming the thread if heat alone fails.
              Working with salt water one knows these things ! Noel.
              #762906
              Mark Salzedo 1
                @marksalzedo1
                Really grateful for all the good advice. A little limited on tools/equipment but probably have a G clamp to fit the cylinder block and dowel. Work in garden for my wife is taking precedence over everything at the moment but hope to work on cylinder/piston in the next week or so!
                #763413
                Mark Salzedo 1
                  @marksalzedo1
                  Good news. Just pushing a 16mm wooden dowel into the bore and pushing hard released the piston. It now slides freely in the cylinder. A big thank you to all of you who kindly took the time to share your suggestions. Now to put it all back together again!
                  #763417
                  Mark Salzedo 1
                    @marksalzedo1
                    I’ll post a video, if and when, I manage to get it running on air.
                    #763421
                      Well done, Mark
                      I’m sure we are all keen to see it run.
                      Mark Salzedo 1
                        @marksalzedo1
                        Thanks Michael.
                        #763449
                        noel shelley
                          @noelshelley55608
                          Nothing better than a good outcome Mark. Good Luck. Noel.
                          #763463
                          Mark Salzedo 1
                            @marksalzedo1
                            Thanks Noel.
                            #767352
                            Mark Salzedo 1
                              @marksalzedo1
                              If anyone is interested, here’s a short video of the Tich running on the cylinder that had a stuck piston. It needed new gaskets and gland packing. I’ll upload another when it’s running on both cylinders. Thanks again for all the advice.
