Hi Clive, I worried about the same thing when making a few recently. Then I realised that such short pins don't need much strength, but my spanners are quite small.
you should be able to buy some Piano Wire of that diameter from your local Aero model shop it is hard stuff but you could cut it with a mini cutting disc and a Dremel or similar Drill.
Author
Please log in to reply to this topic. Registering is free and easy using the links on the menu at the top of this page.
