Not strictly a traction engine query but the nearest forum I could think of to pose this question.
I have a Wheelhorse garden tractor and the king pin/stub axle is made from a bent piece of 3/4″ steel with an annular flange forged into it to act as a bearing stop for the wheel bearings and a steel plate welded onto it to act as the thrust plate for the king pin.
Both the stub axle portion and the king pin bearing areas are worn and I want to replace them, manufacturing my own to suit.
I would like the opinion of experienced traction engine bulders as the problem is quite related to the steering principles of a TE.
What grade of steel do I use, are there any hardening considerations (I have bored out the cast iron bearing surfaces and replaced them with phosphor bronze) will welding flanges on weaken the unit or am I safe to have them welded.
If more information is needed I will furnish a photo or two.
Best regards,
Mick
