Day 35.
The Pulley.
The hardest parts here (for me) was perhaps having to fit the reversible jaws in the 3 Jaw chuck, took ages to get them to engage all together, also truing up the end recess's using the tools I had….
The Pulley Drawing.
The Pulley casting as supplied.
Cleaning up and facing the Pulley casting.
Drilling the central hole in the Pulley.
Checking the Crankshaft for size in the Pulley.
The only tool I had to fit in truing up the outside of the Pulley Boss this side was a Parting Off tool.
Using a small Boring Tool to true up the end recess in the Pulley, it just about fitted through. The Parting tool was too deep beneath the cutting edge for this side of the recess.
Using a Parting Tool to do the Pulley grooves.
Using reverse gear on the Lathe to true up the other end recess in the Pulley, tuning on the back edge of the Pulley Boss (this was the only Parting Tool I had to fit in the recess – it would not fit the front edge of the longer Boss on this end). The reversible chuck jaws holding the Pulley.
Lining up the drill to drill at Centre over the Pulley boss for the grubscrew hole.
Using a Centre Drill to start the Pulley grubs crew hole.
Tapping the Pulley grubscrew hole 5BA.
The finished Pulley 1.
The finished Pulley 2.
Regards.
Allan.
