Thanks again both.
Day 24.
The Cylinder Covers.
Have made a start on the Cylinder Covers. Made a slight error in drilling and not allowing for the drill tip. Can anyone tell me when reading a drawing and looking at the given drill depths is it usual for the measurement to include the length to the tip of the drill or to the point where the drill stops cutting to full width? Hope that makes sense. I will need to make the Front Cover Gland slightly longer as a result and hope that will be ok..
I used the 3 jaw chuck – only had the Locating Spigot to hold on to for the Casting of the Front Cover but it seemed surprisingly solid and held ok. It did mean turning right up to the chuck but again seemed to go ok.
Need to make the Front Gland next and then do the ring of fixing holes…
The Cylinder Cover Drawings.
The Front Cylinder Cover Casting.
Holding onto the Locating Spigot.
Having to Turn right up against the Chuck.
Drilling the Front Cylinder Cover.
The Front Cylinder Cover – no fixing holes yet. (The hole is central – bad camera angle).
The Bar supplied for the back Cylinder Cover.
Test fitting the rear Cylinder Cover. No fixing holes yet.
Test fitting the front Cylinder Cover – no fixing holes yet,
Allan.
