49.
The Eccentric Rod and Clevis.
Just one piece of Mild Steel supplied for the Eccentric Rod, Clevis and two levers (yet to do those). I don't yet have any specific equipment for 'bending' so measured the 'fold' lines for the Clevis off the Drawing (1:1 scale) and bent in the vice, not ideal as it left lots of marks to remove for later.. One slight mistake was to make the two fixing holes in the clevis just slightly too far apart resulting in the fold line being a bit too close to the one hole – that was me using the eccentric stap to spot through thinking to get the spacing the same at both ends and looking better but which was not needed. Should have taken the spacing off the drawing…
The supporting rod I used for the filing buttons was slightly too small in diameter this time – I can see now that this needs to be a close fit to be able to do a good job rounding off – another lesson finally learned I hope with these.
The Eccentric Rod and Clevis Drawing.
Drilling the Eccentric Rod. I used the Eccentric Strap to spot through to the Rod to get them lined up properly.
The Eccentric Rod so far after drilling and rounding off the Clevis end, using filing buttons again.
Drilling the Clevis using the Eccentric Strap to spot through again (mistake as explained above). Should have just used to spot through for just one of the holes to allow lining up for the second..
After all the holes were drilled in the Clevis and the end rounded off it was bent in the vice using a few gentle taps with a hammer and with the Lever being tested in 'position' to get it lined up correctly. The Clevis was then used to spot through to the Rod with the Lever and fixing bolt in position.
Spotting through the Clevis to the second bolting hole. You can maybe see the one bolt a bit close to the fold line, its very slight and sits just about ok – I don't think it will notice.. I was lucky I think.
The Finished Eccentric Rod and Clevis 1.
The Finished Eccentric Rod and Clevis 2.
Just need to clean them all up now before fitting on the Engine…
Regards.
Allan.
Edited By Allan. on 21/02/2014 13:11:41
